I`m installing Nextcloud v.28.0.1 by tutorial How to install Nextcloud on CyberPanel and set up the config to remove index.php from url.
'htaccess.RewriteBase' => '/',
'htaccess.IgnoreFrontController' => true,
index.php disappeared from url, but a warning appeared in Nextcloud:
Your web server is not properly set up to resolve “/ocs-provider/”. This is most likely related to a web server configuration that was not updated to deliver this folder directly. Please compare your configuration against the shipped rewrite rules in “.htaccess” for Apache or the provided one in the documentation for Nginx at it’s documentation page
. On Nginx those are typically the lines starting with “location ~” that need an update.
If I open https://domain/ocs-provider/ I see an error “Page not found”.
.htaccess:
<IfModule mod_rewrite.c>
Options -MultiViews
RewriteRule ^core/js/oc.js$ index.php [PT,E=PATH_INFO:$1]
RewriteRule ^core/preview.png$ index.php [PT,E=PATH_INFO:$1]
RewriteCond %{REQUEST_FILENAME} !\.(css|js|mjs|svg|gif|png|html|ttf|woff2?|ico|jpg|jpeg|map|webm|mp4|mp3|ogg|wav|flac|wasm|tflite)$
RewriteCond %{REQUEST_FILENAME} !/core/ajax/update\.php
RewriteCond %{REQUEST_FILENAME} !/core/img/(favicon\.ico|manifest\.json)$
RewriteCond %{REQUEST_FILENAME} !/(cron|public|remote|status)\.php
RewriteCond %{REQUEST_FILENAME} !/ocs/v(1|2)\.php
RewriteCond %{REQUEST_FILENAME} !/robots\.txt
RewriteCond %{REQUEST_FILENAME} !/(ocs-provider|updater)/
RewriteCond %{REQUEST_URI} !^/\.well-known/(acme-challenge|pki-validation)/.*
RewriteCond %{REQUEST_FILENAME} !/richdocumentscode(_arm64)?/proxy.php$
RewriteRule . index.php [PT,E=PATH_INFO:$1]
RewriteBase /
<IfModule mod_env.c>
SetEnv front_controller_active true
<IfModule mod_dir.c>
DirectorySlash off
</IfModule>
</IfModule>
</IfModule>
Please help me.
P.S. Nextcloud 24.0.12 ver. had the same problem
