Hi!
We’re trying to set up a secondary Domain that points to the same Folder as our primary Domain. Setting the path in the config directly to the Folder we want to show does not work tho.
Any other Way to do this?
Hi!
you can do it from vhost give the vhost home directory to both
tried exactly that, .net domain is up and running and i tried pointing the .io domain to
docRoot /home/xxx.net/public_html/public
but it won’t work
added domains separately? try to add the subdomain under main one
its not a subdomain.
1 is link(.)net and the other is link(.)io
you can add the domain as a subdomain or you can open a ticket on the platform we will help you.
