Hi. How to open all LiteSpeed settings that showed in this guide? litespeed_wiki:config:mitigating-ddos-attacks [LiteSpeed Wiki]
I can see only this page /tuning/litespeedTuning with 6 parameters.
They are not in cyberpanel, they are in litespeed webadmin.
You can access it at yourdomain.com:7080
If you have any problems then make sure that port 7080 is open in the firewall in cyerpanel.
There is a guide here: [Tutorial] How to setup and login to OpenLiteSpeed webadmin console - Blog Posts - CyberPanel Community
If you didn’t make a note of the password when you installed…
You can reset it from the command line:
cd /usr/local/lsws/admin/misc
./admpass.sh
