Hello, have anyone tried installing Chatwoot 2 with docker in Cyberpanel? Chatwoot have published a very nice user manual to do this from terminal (Docker Setup | Chatwoot), but I guess it is best to do it in cyberpanel. If anyone have experience or maybe found an step by step instruction or video please let me know ![]()
Welcome and Happy New Year @mgmt
Start here 3 - Create Docker Container then make sure you set the important env variables here on your setup
Points to take away before starting Docker Chatwoot Production deployment guide | Chatwoot, Step 6 of Docker Chatwoot Production deployment guide | Chatwoot you will use Reverse Proxy Traffic to Docker Container on CyberPanel
Thanks for getting back to me joseph. Tried it, but didnt work. First of all port 3000 is already in use on server, and I dont know how to tell docker to use a different port ![]()
Checked the documentation and still no way to do this ideally this should work simply by adding an .env variable. Kindly raise the issue on GitHub
