How to install and use Imunify360 on CyberPanel
Please update to latest version of cyberpanel. This issue is resolved. Btw, how imunify360 calcluates users in centos/cyberpanel installation? i am on 15 days trial license now, after that i will take single user licence.
Hi!
@iamstevenelson thanks for your tip, unfortunately, for me the issue persists.
My issue is the same as yours (posted in the other thread) and the issue from @liufunyu, only for me, the issue is also with a fresh Almalinux 8 install.
After installation the IMF360 service seems to be running fine, but there is no folder /usr/local/CyberCP/public/imunify(*).
Did you guys manage to resolve the issue, and did you do something else with the installations that might have made it work?
I tried on
  • a fresh CloudLinux OS 8 install with fresh CyberPanel v2.3.4 (which includes the proposed fix) and v2.3.2
  • a fresh AlmaLinux 8 install with fresh CyberPanel 2.3.4 and v2.3.2 (because this worked for @liufunyu )
I noticed the following errors during the installation:
sed: can’t read /usr/local/CyberCP/public/imunify/assets/js/config.js: No such file or directory
No supported panel detected
WARNING: /usr/local/CyberCP/public/imunify is not a directory (it should be created by the imunify deploy script). UI will not be installed.
Hope you guys resolved the issue and might be able to give us a few tips!
Thank you in advance.
cd /usr/local/CyberCP/public/imunify
and chmod +x ./bin/execute.py
Hello, I have a server with cyberpanel installed where we configure cloudlinux perfectly.
Imunify 360, on the other hand, generates the following error to install:
WARNING: /usr/local/CyberCP/public/imunify is not a directory (it should be created by the immunify deploy script). UI will not be installed.
Not being able to manage immunify through cyberpanel
Current Version:
2.3
Build:
4
Current Commit:
d32d25fa9acd163e5bcffebd05f0dd565710e964
Latest Version:
2.3
Latest Build:
4
Latest Commit:
PS. I’ve already updated the cyberpanel to the latest version, I’ve reinstalled the imunify and the error is the same
The click and go in Cyberpanel is broken somehow and I could only install it manually on AlmaLinux.8.8
Still can’t login on the normal way, but need to run
$ imunify360-agent login get --username root
That will give me a token to log in,
https://switch.domain.com/imunify/#/login?token=
I need to repeat this step everytime on a new login. Seems super secure this way.
comodo mod security does not appear in “Mod security rules packages” even though I did the installation step by step. I had CSF installed, I deleted it, I restarted Cyberpanel but it is still not there.
