Hello everybody, may someone help me to install and activate mod_pagespeed as well in cyberpanel?
Thank you
Thank you
It is already installed, however, you can configure using this guide: http://open.litespeedtech.com/mediawiki/index.php/Help:Modules:PageSpeed#Setting_Up_The_PageSpeed_Module
How active can you help me, I could not please
Use that wiki to activate modpagespeed → http://open.litespeedtech.com/mediawiki/index.php/Help:Modules:PageSpeed#Setting_Up_The_PageSpeed_Module
You need only to add the module and put this in the module parameters:
pagespeed on
pagespeed FileCachePath /tmp/lshttpd/pagespeed
pagespeed RewriteLevel CoreFilters
After that restart OLS, clear the cache for your page and you will see “x-ls-pagespeed” in the header of your page.
I configured the module per the directions in this thread. After configuration, I started getting error messages stating directories could not be made by the module. These errors included:
2018-07-05 08:25:08.849431 [ERROR] [modpagespeed] Could not create directories for file
I do not have cache enabled at the same time as per the official guide.
I created the directory /tmp/lshttpd/pagespeed and set the permissions to nobody:nobody drwxr-xr-x but that didn’t seem to fix the issue.
