I’m Using Digital Ocean + LS Ent + Cyber Panel
for My WordPress Website https://fastunlocker.com/
I’m seeing a Notification Under WordPress Dashboard - Site Health.
The REST API is one way WordPress, and other applications, communicate with the server. One example is the block editor screen, which relies on this to display, and save, your posts and pages.
The REST API request failed due to an error.
Error: cURL error 28: Operation timed out after 10001 milliseconds with 0 out of -1 bytes received (http_request_failed)
Another Notification
Loopback requests are used to run scheduled events, and are also used by the built-in editors for themes and plugins to verify code stability.
The loopback request to your site failed, this means features relying on them are not currently working as expected.
I saw some Online Tutorials to Fix this
https://www.samuelaguilera.com/post/curl-error-28-wordpress
I’m a little bit confused to do a FIX My Self…
So, Can You Please Help me out…
