I have installed fmpeg
But, now i need enable ffmpeg-php.
I check on php extension but there is not.
How to enable it now?
You need to install ffmpeg and ffprobe, after that you can use php-ffmpeg ins you project by using PHP composer here is a guide
Can you give me commands?
Step by step.
