My Cyperpanel auto run backup at 3.00 AM . How can I turn it off ?
Thank you
I have checked it but nothing there, I have never set up any Schedule Backup
Remove cronjob entries from crontab file
/etc/crontab
Remove if you see this command python /usr/local/CyberCP/plogical/backupSchedule.py
How can I create exceptions? I mean, accounts that will not do backup.
How do i recognize a cronjob entries ?
Is it fixed for newer versions of Cyberpanel ?
sudo crontab -e
#0 12 * * * /usr/local/CyberCP/bin/python /usr/local/CyberCP/IncBackups/IncScheduler.py Daily
#0 0 * * 0 /usr/local/CyberCP/bin/python /usr/local/CyberCP/IncBackups/IncScheduler.py Weekly
