I’m trying to customize error pages like 404 or 500, though I’m not getting via htaccess, would it have some form?
@usmannasir said:
You can do this via web admin console.Virtual Host > General > Customized Error Pages
Dude is not finding this option, stay inside that flap?
@usmannasir said:
And
On this page, you will find Customized Error Pages
So my panel is different from that print that you
@usmannasir said:
https://forums.cyberpanel.net/discussion/87/tutorial-how-to-setup-and-login-to-openlitespeed-webadmin-console#latest
I have already thank you, just a question, adding the error pages in Example that will lock default to all hosts or not?
@usmannasir1 hi bro I am using latest litespeed server …I could not fount any options like this…could you please help me?
You will need to login to your litespeed/openlitespeed webadmin console for this.
YourserverIPaddress:7080 will be your webadmin console.
YourserverIPaddress:8090 is your cyberpanel dashboard and IP:7080 is your litespeed/openlitespeed webadmin console.
I could not see any error pages option in new version litespeed server.could you please explain me
Do follow the screenshots provided in the above posts by usman. It clearly pinpoints where to check.
This interface not available now…in my litespeed vhost and vhost template showing empty
Do you have sites hosted in your server?
Yes but its not showing any thing
Try restarting you server or else create vhost manually for your websites.
