I’m new to CyberPanel, which uses the LiteSpeed web server. Currently, I am using ISPConfig and would like to transfer to CyberPanel. However, I’m having trouble understanding some of the configurations. For instance, I’m currently struggling with Memcached. After a fresh install and running my first site on CyberPanel, it seems that Memcached is already installed, as indicated by the following message:
Memcached Extension: Enabled
Redis Extension: Enabled
Connection Test: Passed
However, when I open my website, especially the homepage that has a lot of queries due to a complicated setup similar to a newspaper, the speed is very slow compared to W3TC.
When I used ISPConfig and Ubuntu, I would install Memcached using the following command:
While using ISPConfig and Ubuntu, I used to install memcached using:
apt install memcached
Then, to check if it is running, I would use this command:
service memcached status
But in CyberPanel, I can’t find this service.
Can anyone please explain how I can determine if Memcached is installed by default in CyberPanel and why I can’t find such a service?
Thank you.
