how to change max_input_vars?
I am a new user and wanted to greatly alter max_input_vars
but I already changed in the php advenced and even then it does not apply in the sites how can it be solved ??
Help
help
You need to check which version your site is using, also show us your phpinfo page.
Screenshot by Lightshot openlitespeed Screenshot by Lightshot
Please remove ; before max_input_vars
I’ve tried to apply it several times and I’ve even created a php.ini php.user edit in the .htacess without result
Did you remove ; ?
removing ; and then restarted the server > loved
Thanks !! All afternoon searching for this ! Love u !
