How to automate the upgrade for Cyberpanel?
Hi Guys,
I’m new here. I just want to get a few insights about How to automate the upgrade for Cyberpanel. Thank you
as far as i can remember
the only only one interactive between screen and user is only at the beginning to check the version and that have timeout to default option
maybe you can create new script
screen (if your distro can/have screen )
(execute the upgrade command)
save
put that sh to crontab
or you can check the version at git
then if different run upgrade-syntax else
exit
put that sh at crontab
Can you give an example for crontab?
im not good in “manual” crontab
maybe other member can help you
Thanks Mate
You can setup automatically CyberPanel upgrade everyweek. Follow this link - https://mpateldigital.com/how-to-upgrade-cyberpanel-automatically-every-week/
