Recently I Created a Digital Ocean Droplet > Installed Cyber Panel + OLS Using SSH.
Created a Website Under Cyber Panel
Created Email ID for that Site Under Cyber Panel
Now Able to Send Emails From Rainloop Web Email Provided by Cyber Panel.
Created DKIM + SPF in Digital Ocean Domain Settings ( Copied Records from Cyber Panel )
After Records Created in Digital Ocean, I send some Mails from Rainloop.
All That Emails Verified and Signed.
The receiver Can See, Mailed by and Signed by Details.
Till, This everything is fine ( I think ).
Correct?
OK…
Now, The Problem.
I wish to send emails from my website.
So, there I need a few things.
1 - SMTP Host
2 - Port
3 - User ID
4 - Password
I know User ID and Password, which I’m using to Login in Rainloop.
Port mostly 465 and 587 ( I saw this in SSH, once OLS Installation Finished )
But, SMTP Host…
When I checked Records under DNS, I could see " mail.mydomain.com "
most f the situation, that’s correct.
that should be correct, because from there only I took DKIM and SPF, they worked good.
So,
I added mail.mydomain.com in Digital Ocean as A records.
then,
goto my web application.
and put these settings
SMTP - mail.mydomain.com
Port - 465
User Name - [email protected]
password - secret password
But, My web App saying - Unable to connect to host.
What I missed to do?
mail.mydomain.com should be created in Digital Ocean as A Record or TXT?
or as CNAME?
Only I have confusion on this…
Maybe the error is something else.
I have described almost everything I know…
kindly help me to sort out the issue…
Thanks.
