I’d like to secure 7080 port via hostname ssl feature too, can this be done manually or as a feature on next update?
Just generate an SSL for your default vhost in Cyberpanel and it should be applied to lscpd also. If not, check Virtual Hosts->Your default VHost->SSL tab and add a path to a cert and key there which are located at /etc/letsencrypt/live/YOUR_DEFAULT_DOMAIN/privkey.pem & fullchain.pem
Also check the comments section here: [Tutorial] How to setup and login to OpenLiteSpeed webadmin console — CyberPanel - WebHosting Control Panel for OpenLiteSpeed
