Someone here uses Hetzner VPS? I create a server, added a website, issue a Hostname SSL for this website but I can’t access the Cyberpanel by https://mydomain.xyz:8090… When I only enter https://mydomain.xyz it shows the "CyberPanel Installed"message (this means that site is correct installed).
But doesn’t enter when add :8090 (keeps loading for a while, after give a error message).
This never happened with me in DigitalOcean or Vultr.
PS: I created a firewall with 8090 TCP open
Even with ipaddress:8090 doesnt open cyberpanel for you?
Thanks for your answer. I already found the problem. I can’t use domain br Proxy (Cloudflare) to acess with :8090. Just turned off and everything was ok!
Thanks anyway
