Hello!
I just try to send one email and I get:
Hostname/IP does not match certificate’s altnames: Host: mail.botden.cf. is not in the cert’s altnames: DNS:botden.cf, DNS:www.botden.cf
The cyberpanel web email works though.
My mail server runs on postfix - on CyberPanel.
Hope someone can help!
your domain’s ssl is good.
if you talk about the mail …
as far as i can see
you only need change your computer’s dns
then flush the dns ipconfig /flushdns
but, if …
what mail client you use ?
Hmm…I’m using nodemailer, which is a way to send email via code. I also tried the default mail app on Windows just as a test, but it didn’t even let me log in - it says we couldn’t find info for that account.
The config I’m using with nodemailer is:
host: mail.botden.cf
port: 25
TLS disabled
work fine at gmail
