Hostname change not working after setup help needed
Server Ubuntu 24.04.3 LTS
Cyberpanel version 2.4 build 4
Hi
I tried to change the hostname from ip to domain.
I follow the next steps
  • I created DNS A registry on Cloudflare from my subdomain to my IP server
    adpan.as12.top > 154.xxx.xxx.xxx
  • I set rDNS on both IPV4 and IPV6 on contabo from my IP to the subdomain
  • I change the setup on file /etc/hosts in my server
  • On cyberpanel go to wizard configuration set the new domain on hostname field but I get “Domain that you have provided is not configured as rDNS for your server IP. [404]”
I go to https://dnschecker.org/ to check the DNS configuration and it shows the correct ip from my subdomain.
I have tried every setup in here and on the onboarding web page in cyberpanel and nothing works.
Can someone please help me I’ll appreciate it.
Same problem here, contabo vps as well…
Im still with the issue..
Nobody answer
I’m searching the web, I’ll let you know if something came up
