hostname:8090 SSL error
I’m having several hosts and on some I get SSL error (loading example.com)
while access https://host.tld:8090 but not on https://host.tld using custom SSL
I know in cyberpanel ssl should be added in SSL section to hostname
but on some machines it’s working like a charm and on others no way
don’t have the issue with letsencrypt SSL only with custom SSL
custom SSL is valid ( tested and seen via serveral SSL checkers)
what could be the problem , it’s NOT the SSL
cyberpanel panel is all last version
Same here. On Ubuntu 20.04. On one system no problem - on the other only self-issued certificate for https://host.tld:8090. I have the issue with Let’s Encrypt SSL…
Same issue here with Ubuntu 20.04
Hostname:8090 SSL error for the panel only, the Let’s Encrypt SSL works fine for the domain name …
Seems that acme.sh is not working properly on cyberpanel. Acme.sh now uses zerossl
Resolves after some acme.sh’s issues research …
Thanks to the community
