Help with Setting Up SSL on My CyberPanel Server
Hi all,
I’m relatively new to CyberPanel and setup my server for a couple of sites. I want to secure my sites with SSL certificates, but have been running into some snags. I have used the AutoSSL feature in CyberPanel and while the cert installs, some of the pages are showing, not fully secure (mixed content errors).
I have checked and double checked the common issues, but I can’t figure out what is causing this. Perhaps there is a step that I have missed in configuring the SSL? I am also wondering if there is anyone here that has experience with installing Let’s Encrypt certificates on CyberPanel and is it possible to set them up on several domains at once?
Any and all advice would be much appreciated!
Thanks in advance and looking forward to hear your suggestions and insights,
Best,
martin
