Hi i just messed with thedns records and removed some of them please how i can completely reset all records to the default.
Right now there is no option to just reset DNS records. You can however, look at default records of other domains and replicate them
If i delete the dns zone and i add it again will that work ?
yes sure please consider if you use CF, it will include DNS already
