ive tried to run cronjob in every way but still not working please help me
here is the command im using laravel php artisan schedule:run
what do you want cronjob do so we can help you ?
did you read this simple guide CronJob
thank you for the reply herei want to run a laravel command like this
cd /domain.com && php artisan schedule:run >> /dev/null 2>&1
but it wont work
Can you try
/usr/local/lsws/lshphpXX/bin/php /home/domain.com/public_html/artisan schedule:run >> /dev/null 2>&1
By the way I don’t exactly know how laravel works.
But if you run above command from CLI what happens?
Try following from cli
Note: replace XX with your PHP version like 74 or 80 etc.
Well as per docs this should work (Task Scheduling - Laravel - The PHP Framework For Web Artisans)
cd /home/domain.com/public_html && /usr/local/lsws/lshphpXX/bin/php artisan schedule:run >> /dev/null 2>&1
ive tried it nothing happened i dont know where cron root running path or the log file ?
no help yet any soulution
Which php version you are using?
Send me a private message with your php version for the domain and also the domain name.
I recently read the blog about Cron jobs its really help me. you must read this blog its might that help you
How To Use Cron Jobs With Laravel?
