I have been getting frustrated with Cyberpanel for the last 4 to 5 hours I have been trying to add files in the file manager in one of my subdomains to create an admin panel for my android app. Here is what I am trying to do and what problem I face.
First I created a subdomain and open the subdomain Cyberpanel I Installed the page open
which means the domain was created successfully. Now I visited the file manager and deleted the default index.html file and upload my admin panel files. After this when I again open the domain I was continuously getting ERR_TOO_MANY_REDIRECTS then I go through many community posts regarding the same problem. What I understood this may occur due to the .htaccess so from the dashboard of the subdomain I open the redirect rule option and copy the rewrite rules and then delete the rule and save the file and load the domain the problem was still there so I again opened redirect rules and paste the code and save it and again load the website. Since then I am getting two new problems one is 500 Server Error and another one is ```
Composer detected issues in your platform: Your Composer dependencies require a PHP version “>= 8.1.0”. Though I have installed the subdomain at PHP 8.1 I was still getting this error. I tried to edit the compose.json file and downgrade the PHP requirement but nothing worked. -
Sometimes when I deleted the default index.html file and uploaded the admin panel files I was again getting 505 Server Error message.
I tried to remove the domain and add it again but nothing worked I changed the URL of the sub domain but it also does not worked
I checked the error log of my sub domain and it was like below
2022-08-19 04:57:08.854299 [ERROR] [189727] [172.70.174.81:17920] URI '/hap/config.json/' refers to a static file with PATH_INFO [/].
2022-08-19 04:57:09.246071 [ERROR] [189727] [172.70.174.81:17920] URI '/hap/config.json/404.html' refers to a static file with PATH_INFO [/404.html].
2022-08-19 04:57:09.578731 [ERROR] [189727] [172.70.174.81:17920] URI '/hap/config.json/404.html' refers to a static file with PATH_INFO [/404.html].
2022-08-19 04:57:09.863150 [ERROR] [189727] [172.70.174.81:17920] URI '/hap/config.json/404.html' refers to a static file with PATH_INFO [/404.html].
2022-08-19 04:57:10.151968 [ERROR] [189727] [172.70.174.81:17920] URI '/hap/config.json/404.html' refers to a static file with PATH_INFO [/404.html].
2022-08-19 04:57:10.448201 [ERROR] [189727] [172.70.174.81:17920] URI '/hap/config.json/404.html' refers to a static file with PATH_INFO [/404.html].
2022-08-19 04:57:10.756893 [ERROR] [189727] [172.70.174.81:17920] URI '/hap/config.json/404.html' refers to a static file with PATH_INFO [/404.html].
2022-08-19 04:57:11.047344 [ERROR] [189727] [172.70.174.81:17920] URI '/hap/config.json/404.html' refers to a static file with PATH_INFO [/404.html].
2022-08-19 04:57:11.371743 [ERROR] [189727] [172.70.174.81:17920] URI '/hap/config.json/404.html' refers to a static file with PATH_INFO [/404.html].
2022-08-19 04:57:11.675553 [ERROR] [189727] [172.70.174.81:17920] URI '/hap/config.json/404.html' refers to a static file with PATH_INFO [/404.html].
2022-08-19 04:57:11.959222 [ERROR] [189727] [172.70.174.81:17920] URI '/hap/config.json/404.html' refers to a static file with PATH_INFO [/404.html].
