Help in enabling ZipArchive (sudo yum install -y lsphp8.1-zip)
I tried running sudo yum install -y lsphp8.1-zip but it’s unsuccessful.
Here’s the commands: (Please not, I’m a newbie)
sudo: yum: command not found
vener@Veners-MacBook-Pro-5 ~ % which yum
yum not found
vener@Veners-MacBook-Pro-5 ~ % sudo dnf install yum
Password:
sudo: dnf: command not found
vener@Veners-MacBook-Pro-5 ~ % sudo yum update
Password:
vener@Veners-MacBook-Pro-5 ~ % # rpm -q yum
zsh: command not found: #
vener@Veners-MacBook-Pro-5 ~ % rpm -q yum
zsh: command not found: rpm
vener@Veners-MacBook-Pro-5 ~ % # sudo dnf install yum
Password:
vener@Veners-MacBook-Pro-5 ~ % sudo yum install
vener@Veners-MacBook-Pro-5 ~ % [200~yum install epel-release -y~
zsh: bad pattern: [200~yum
vener@Veners-MacBook-Pro-5 ~ % yum install dnf
zsh: command not found: yum
Please help
Why running these commands on mac PC?
Are you trying to install cyberpanel on mac?
