Website takes time to respond. I guess gzip compression may be a reason.
I have 2 concern regardingh gzip:
- Can we enable or disable gzip compression as per each website?
- Can we add exception to files which we do not want to compress?
Is it possible to do so??
qtwrk
#2
for domain level enable/disable , yes , via webadmin console ,
but for file extension , i am not sure
What is webadmin console?
moataz
#4
ols= openlitespeed u can access http://yourip:7080 make sure u enable the port in cyberpanel security and default access is admin / 123456
Hello
I have “Enable Compression” in “Yes” and also in Tuning (server config)
But when i test site in gtmetrix.com i get:
Enable gzip compression F(0)
What I loosing here?
Thanks
Fabian
done!
Adding the lscache plugin in the site with WP, Gzip was activated
Is weird that gzip not activate in HTML sites ;(
Fabian
