I recently had a serious problem with the logs, the switchLSWSStatus file weighed over 700GB. Therefore I decided to share my script with you to always keep the server logs clean.
FOLLOW MY GUIDE
sudo -i
cd /root/
nano logscleaner.sh
Paste this code:
#!/bin/bash
# Software Logs Cleaner v1.0alpha, use only for test
# Powered by Nicholas Sciortino
# clear all logs of CP
rm -rf /usr/local/lsws/logs/*
# clear OpenLiteSpeed cache folder
rm -rf /usr/local/lsws/cachedata
# remove old CyberPanel versions
rm -rf /usr/local/*.tar.gz
# clear other logs
rm -f /home/cyberpanel/switchLSWSStatus
rm -f /home/cyberpanel/stderr.log
rm -f /home/cyberpanel/error-logs.txt
After you have to give permissions to the executable file
chmod +x logscleaner.sh
Now you can run it manually with the command, after you have cleared all logs and freed up a lot of memory ^^
sh logscleaner.sh
We can also automate cleanup using a cron
crontab -e
At the end of the file add
0 0 * * 0 sh /root/logscleaner.sh
Once a week the script will be executed which will delete all the logs
