GUI Login Not working
Cyberpanel V2.4.4
Ubuntu 22.04.5 LTS
i am having trouble login into the main GUI eg.mydomain:8090
server is running no issues Cyberpanel is running no issue
SSH login no issues and no errors in the log.
if i attempt login to the with correct details it just reloads the login page if i use wrong user or password it gives login error normal,
i changed my login password via SSH adminPass newpassword and same result just reloads the login page with no errors.
Make sure you are not using a VPN, delete your browser cookies and try again.
Not using a VPN and I did clear the browser history no such luck. I have logged in via SSH and added a new admin user which worked. reset the actual admin use password and still won’t access.
so this new user as an admin account will have to o from now on lol.
Have same problem. But founded what is wrong. Now you can’t use symbols like ` in password. I created new admin, modified password of old admin, and logged in.
