Hi, I am running two different cloud servers, both using Cyberpanel and Ubuntu 22.04.1
On one of the servers, I am able to connect to FTP without any issue.
On the second one which I had installed today, I am receiving Error 530 for several different FTP accounts which I have set up for different websites. The hostname resolves to the IP address. The usernames and passwords are correct. Ports are open and pausing the Cyberpanel Firewall doesn’t change anything.
FileZilla:
|Status: |Verbinde mit 5.xxx.xxx.xxx:21...|
|Status: |Verbindung hergestellt, warte auf Willkommensnachricht...|
|Status: |Initialisiere TLS...|
|Status: |TLS-Verbindung hergestellt.|
|Befehl: |USER admin_xxxxxxxx|
|Antwort: |331 User admin_xxxxxxxx OK. Password required|
|Befehl: |PASS *******************|
|Antwort: |530 Login authentication failed|
|Fehler: |Kritischer Fehler: Herstellen der Verbindung zum Server fehlgeschlagen|
FTP Server Log entries:
Jan 2 16:44:48 Cloud2 pure-ftpd: (?@p5b321cfd.dip0.t-ipconnect.de) [INFO] New connection from p5b321cfd.dip0.t-ipconnect.de
Jan 2 16:44:48 Cloud2 pure-ftpd: (?@p5b321cfd.dip0.t-ipconnect.de) [INFO] TLS: Enabled TLSv1.3 with TLS_AES_256_GCM_SHA384, 256 secret bits cipher
Jan 2 16:44:52 Cloud2 pure-ftpd: (?@p5b321cfd.dip0.t-ipconnect.de) [WARNING] Authentication failed for user [admin_xxxxxxxx]
Jan 2 16:44:53 Cloud2 pure-ftpd: (?@p5b321cfd.dip0.t-ipconnect.de) [INFO] Logout.
What can I do to make FTP Access work? It seems that many users are asking the exact same question during the last months, also here in the forum…
Thanks!
