https://imgy.host/1z9zb1ub.png
I guess I wasn’t able to read! Lol, okay anyways, now with disabling firewall it wont work anymore, default startup = turning on the firewall
We do not support Ubuntu 16.04, plus 18.xx are supported in beta. Centos 7.x is officially supported stable OS.
I created a server on Digital Ocean on Ubuntu 18.04, for now I should only use pure wordpress, without being able to add plugins because cpanel doesn’t work, correct? It has forecast? It’s very bad that way, because we can’t evolve the site, it ends up serving nothing.
I can’t start pureftpd, this happened after the update, didn’t change anything by myself.
Oct 22 11:34:00 server systemd[1]: Can’t open PID file /var/run/pure-ftpd.pid (yet?) after start: Too many levels of symbolic links
Oct 22 11:34:00 server pure-ftpd[4321]: (?@?) [DEBUG] Couldn’t load the DH parameters file /etc/ssl/private/pure-ftpd-dhparams.pem
After hunting over all of these posts for an answer I figured this one out.
For anyone who wants to use the Digital Ocean Cyberpanel Marketplace Installation on a blank droplet - you need to change the IP address inside of this directory file:
/etc/pure-ftpd/conf/ForcePassiveIP
I am not sure WHY there was a random IP address set inside of this file, but once I changed the IP address to match my droplet’s IP address - it works flawlessly now.
Hope this helps people with that dreaded:
ECONNREFUSED - Connection refused by server
