Hello
I tried to connect to ftp of my site and I faild, So I tried these:
first of all, I read about it here and aske many question in direct of @ josephgodwinke
My OS : Ubuntu 20.04
1- the server can’t be upgrade , this is the error:
/usr/local/requirments.txt 100%[=================================================================================================================================================>] 1.43K --.-KB/s in 0s
2023-12-24 17:07:54 (9.96 MB/s) - ‘/usr/local/requirments.txt’ saved [1461/1461]
File "/usr/local/CyberPanel/bin/pip3", line 8, in <module>
sys.exit(main())
File "/usr/local/CyberPanel/lib/python3.8/site-packages/pip/_internal/cli/main.py", line 68, in main
command = create_command(cmd_name, isolated=("--isolated" in cmd_args))
File "/usr/local/CyberPanel/lib/python3.8/site-packages/pip/_internal/commands/__init__.py", line 114, in create_command
module = importlib.import_module(module_path)
File "/usr/local/CyberPanel/lib/python3.8/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 848, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/usr/local/CyberPanel/lib/python3.8/site-packages/pip/_internal/commands/install.py", line 16, in <module>
from pip._internal.cli.req_command import (
File "/usr/local/CyberPanel/lib/python3.8/site-packages/pip/_internal/cli/req_command.py", line 20, in <module>
from pip._internal.index.collector import LinkCollector
File "/usr/local/CyberPanel/lib/python3.8/site-packages/pip/_internal/index/collector.py", line 37, in <module>
from pip._internal.network.session import PipSession
File "/usr/local/CyberPanel/lib/python3.8/site-packages/pip/_internal/network/session.py", line 44, in <module>
from pip._internal.network.cache import SafeFileCache
File "/usr/local/CyberPanel/lib/python3.8/site-packages/pip/_internal/network/cache.py", line 9, in <module>
from pip._vendor.cachecontrol.caches import FileCache
File "/usr/local/CyberPanel/lib/python3.8/site-packages/pip/_vendor/cachecontrol/caches/__init__.py", line 6, in <module>
from .redis_cache import RedisCache
ModuleNotFoundError: No module named 'pip._vendor.cachecontrol.caches.redis_cache'
above command failed...
2- the ftp wont work at all, I just use the sftp and connected with root credentials
is there any way to fix the server problem or I must install the server in fresh os?
