Fresh install of cyberpanel not working
Using AlmaLinux9 latest build of cyberpanel, everything installs okay, but when I want to access it I get error 500.
Error log gives me nothing useful only that request is missing body whatever that means.
Could the problem be domain? Setup gave me public domain like mypublicip:8090 but I’m trying to access it with mylocalip:8090 since I did not forward any ports yet for outside accesss.
I can see in settings.py that it allows ANY host so it should not be a problem then?
Update to the Latest Version/Commit of cyberpanel.
Update? I just installed it, latest version, dont think theres any updates.
Error log says:
[11.21.2024_20-13-29] https://192.168.1.80:8090/favicon.ico
[11.21.2024_20-13-29] Request needs session : /favicon.ico
[11.21.2024_20-13-29] Path vs the final url : /
[11.21.2024_20-13-29] Request method get
[11.21.2024_20-13-29] Request does not have a body.
[11.21.2024_20-15-51] Path vs the final url : /
[11.21.2024_20-15-51] https://127.0.0.1:8090/
[11.21.2024_20-15-51] Request method get
[11.21.2024_20-15-51] Request does not have a body.
So stupid , zero information on what’s wrong.
Share the IP me in DM so that I can check it might be caused because of not proper packages. I suggest running the upgrade script once and then see.
Thanks but due to complexity and inefficient logs I will not be using this panel. What if in the future I encounter another 500 error? There’s no way to figure out what’s wrong, error logs are useless. Really bad project.
Could you please provide the output of the following error log?
/usr/local/lsws/logs/stderr.log
