On a fresh installation of CentOS 7.5.1804 I get the following error when trying to install CyberPanel. I get the same error no matter what version of MariaDB I select
MariaDB 10.3 will be installed
/root/install
usage: install.py [-h] [–mysql MYSQL] [–postfix POSTFIX]
[–powerdns POWERDNS] [–ftp FTP]
publicip
install.py: error: too few arguments
grep: /var/log/installLogs.txt: No such file or directory
CyberPanel installation failed.
Full output below
[root@cyberpanel ~]# sh <(curl https://cyberpanel.net/install.sh || wget -O - https://cyberpanel.net/install.sh)
100 9071 100 9071 0 0 14053 0 --:–:-- --:–:-- --:–:-- 14063
You are runing on root…
pre-flight check 1…
pre-flight check 2…
CyberPanel Installer
RAM check : 222/15886MB (1.40%)
Recommended minimal 512MB for 1 database instance installation.
Recommended minimal 1024MB for 2 databases instances installation.
Disk check : 1011/50GB (2%) (Minimal 10GB free space)
Install CyberPanel with 1 database instance.
Install Cyberpanel with 2 databases instances.
Exit.
Please enter the number[1-3]: 1
You have selected Single Database, Please be mind with RAM requirement.
For MariaDB 10.0 Single Database, Recommended minimal 512MB RAM.
For MariaDB 10.0 Dual Databases, Recommended minimal 1024MB RAM
For MariaDB 10.1 and above:
Recommended 1GB RAM for single databse, and 2GB for dual databases.
Please note, only MariaDB 10.0 is officialy supported by CyberPanel.
Use at your own risk!
Install MariaDB 10.0
Install MariaDB 10.1
Install MariaDB 10.2
Install MariaDB 10.3
Exit.
Please enter the number[1-5]: 4
Loaded plugins: fastestmirror
No Match for argument: epel-release
No Packages marked for removal
Determining fastest mirrors
- base: mirrors.usinternet.com
- extras: mirror.cs.uwp.edu
- updates: mirrors.usinternet.com
base | 3.6 kB 00:00
extras | 3.4 kB 00:00
updates | 3.4 kB 00:00
(1/4): extras/7/x86_64/primary_db | 204 kB 00:00
(2/4): base/7/x86_64/group_gz | 166 kB 00:00
(3/4): updates/7/x86_64/primary_db | 6.0 MB 00:01
(4/4): base/7/x86_64/primary_db | 5.9 MB 00:12
Resolving Dependencies
→ Running transaction check
—> Package epel-release.noarch 0:7-11 will be installed
→ Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Installing:
epel-release noarch 7-11 extras 15 k
Transaction Summary
Install 1 Package
Total download size: 15 k
Installed size: 24 k
Downloading packages:
warning: /var/cache/yum/x86_64/7/extras/packages/epel-release-7-11.noarch.rpm: Header V3 RSA/SHA256 Signature, key ID f4a80eb5: NOKEY
Public key for epel-release-7-11.noarch.rpm is not installed
epel-release-7-11.noarch.rpm | 15 kB 00:00
Retrieving key from file:///etc/pki/rpm-gpg/RPM-GPG-KEY-CentOS-7
Importing GPG key 0xF4A80EB5:
Userid : “CentOS-7 Key (CentOS 7 Official Signing Key) security@centos.org”
Fingerprint: 6341 ab27 53d7 8a78 a7c2 7bb1 24c6 a8a7 f4a8 0eb5
Package : centos-release-7-5.1804.el7.centos.x86_64 (@anaconda)
Running transaction test
Transaction test succeeded
Running transaction
Installing : epel-release-7-11.noarch 1/1
Verifying : epel-release-7-11.noarch 1/1
Installed:
Complete!
Apache is not install or active, to next step…
Named is not installed or active, to next step…
Cleaning repos: base epel extras updates
Cleaning up everything
Maybe you want: rm -rf /var/cache/yum, to also free up space taken by orphaned data from disabled or removed repos
Cleaning up list of fastest mirrors
epel/x86_64/metalink | 18 kB 00:00
- base: mirror.jaleco.com
- epel: mirror.steadfastnet.com
- updates: centos.mirrors.tds.net
base | 3.6 kB 00:00
epel | 3.2 kB 00:00
(1/7): base/7/x86_64/group_gz | 166 kB 00:00
(2/7): epel/x86_64/updateinfo | 933 kB 00:00
(3/7): epel/x86_64/group_gz | 88 kB 00:00
(4/7): extras/7/x86_64/primary_db | 204 kB 00:00
(5/7): epel/x86_64/primary | 3.6 MB 00:00
(6/7): base/7/x86_64/primary_db | 5.9 MB 00:00
(7/7): updates/7/x86_64/primary_db | 6.0 MB 00:02
epel 12756/12756
—> Package bc.x86_64 0:1.06.95-13.el7 will be installed
Installing:
bc x86_64 1.06.95-13.el7 base 115 k
Transaction Summary
Install 1 Package
Total download size: 115 k
Installed size: 215 k
bc-1.06.95-13.el7.x86_64.rpm | 115 kB 00:00
Running transaction
Installing : bc-1.06.95-13.el7.x86_64 1/1
Verifying : bc-1.06.95-13.el7.x86_64 1/1
Installed:
Complete!
—> Package NetworkManager.x86_64 1:1.10.2-13.el7 will be updated
—> Package NetworkManager.x86_64 1:1.10.2-16.el7_5 will be an update
—> Package NetworkManager-libnm.x86_64 1:1.10.2-13.el7 will be updated
—> Package NetworkManager-libnm.x86_64 1:1.10.2-16.el7_5 will be an update
—> Package NetworkManager-team.x86_64 1:1.10.2-13.el7 will be updated
—> Package NetworkManager-team.x86_64 1:1.10.2-16.el7_5 will be an update
—> Package NetworkManager-tui.x86_64 1:1.10.2-13.el7 will be updated
—> Package NetworkManager-tui.x86_64 1:1.10.2-16.el7_5 will be an update
—> Package audit.x86_64 0:2.8.1-3.el7 will be updated
—> Package audit.x86_64 0:2.8.1-3.el7_5.1 will be an update
—> Package audit-libs.x86_64 0:2.8.1-3.el7 will be updated
—> Package audit-libs.x86_64 0:2.8.1-3.el7_5.1 will be an update
—> Package bind-libs-lite.x86_64 32:9.9.4-61.el7 will be updated
—> Package bind-libs-lite.x86_64 32:9.9.4-61.el7_5.1 will be an update
—> Package bind-license.noarch 32:9.9.4-61.el7 will be updated
—> Package bind-license.noarch 32:9.9.4-61.el7_5.1 will be an update
—> Package binutils.x86_64 0:2.27-27.base.el7 will be updated
—> Package binutils.x86_64 0:2.27-28.base.el7_5.1 will be an update
—> Package ca-certificates.noarch 0:2017.2.20-71.el7 will be updated
—> Package ca-certificates.noarch 0:2018.2.22-70.0.el7_5 will be an update
—> Package centos-release.x86_64 0:7-5.1804.el7.centos will be updated
—> Package centos-release.x86_64 0:7-5.1804.5.el7.centos will be an update
—> Package dhclient.x86_64 12:4.2.5-68.el7.centos will be updated
—> Package dhclient.x86_64 12:4.2.5-68.el7.centos.1 will be an update
—> Package dhcp-common.x86_64 12:4.2.5-68.el7.centos will be updated
—> Package dhcp-common.x86_64 12:4.2.5-68.el7.centos.1 will be an update
—> Package dhcp-libs.x86_64 12:4.2.5-68.el7.centos will be updated
—> Package dhcp-libs.x86_64 12:4.2.5-68.el7.centos.1 will be an update
—> Package dracut.x86_64 0:033-535.el7 will be updated
—> Package dracut.x86_64 0:033-535.el7_5.1 will be an update
—> Package dracut-config-rescue.x86_64 0:033-535.el7 will be updated
—> Package dracut-config-rescue.x86_64 0:033-535.el7_5.1 will be an update
—> Package dracut-network.x86_64 0:033-535.el7 will be updated
—> Package dracut-network.x86_64 0:033-535.el7_5.1 will be an update
—> Package e2fsprogs.x86_64 0:1.42.9-11.el7 will be updated
—> Package e2fsprogs.x86_64 0:1.42.9-12.el7_5 will be an update
—> Package e2fsprogs-libs.x86_64 0:1.42.9-11.el7 will be updated
—> Package e2fsprogs-libs.x86_64 0:1.42.9-12.el7_5 will be an update
—> Package firewalld.noarch 0:0.4.4.4-14.el7 will be updated
—> Package firewalld.noarch 0:0.4.4.4-15.el7_5 will be an update
—> Package firewalld-filesystem.noarch 0:0.4.4.4-14.el7 will be updated
—> Package firewalld-filesystem.noarch 0:0.4.4.4-15.el7_5 will be an update
—> Package gnupg2.x86_64 0:2.0.22-4.el7 will be updated
—> Package gnupg2.x86_64 0:2.0.22-5.el7_5 will be an update
—> Package initscripts.x86_64 0:9.49.41-1.el7 will be updated
—> Package initscripts.x86_64 0:9.49.41-1.el7_5.2 will be an update
—> Package iptables.x86_64 0:1.4.21-24.el7 will be updated
—> Package iptables.x86_64 0:1.4.21-24.1.el7_5 will be an update
—> Package iwl100-firmware.noarch 0:39.31.5.1-62.el7 will be updated
—> Package iwl100-firmware.noarch 0:39.31.5.1-62.2.el7_5 will be an update
—> Package iwl1000-firmware.noarch 1:39.31.5.1-62.el7 will be updated
—> Package iwl1000-firmware.noarch 1:39.31.5.1-62.2.el7_5 will be an update
—> Package iwl105-firmware.noarch 0:18.168.6.1-62.el7 will be updated
—> Package iwl105-firmware.noarch 0:18.168.6.1-62.2.el7_5 will be an update
—> Package iwl135-firmware.noarch 0:18.168.6.1-62.el7 will be updated
—> Package iwl135-firmware.noarch 0:18.168.6.1-62.2.el7_5 will be an update
—> Package iwl2000-firmware.noarch 0:18.168.6.1-62.el7 will be updated
—> Package iwl2000-firmware.noarch 0:18.168.6.1-62.2.el7_5 will be an update
—> Package iwl2030-firmware.noarch 0:18.168.6.1-62.el7 will be updated
—> Package iwl2030-firmware.noarch 0:18.168.6.1-62.2.el7_5 will be an update
—> Package iwl3160-firmware.noarch 0:22.0.7.0-62.el7 will be updated
—> Package iwl3160-firmware.noarch 0:22.0.7.0-62.2.el7_5 will be an update
—> Package iwl3945-firmware.noarch 0:15.32.2.9-62.el7 will be updated
—> Package iwl3945-firmware.noarch 0:15.32.2.9-62.2.el7_5 will be an update
—> Package iwl4965-firmware.noarch 0:228.61.2.24-62.el7 will be updated
—> Package iwl4965-firmware.noarch 0:228.61.2.24-62.2.el7_5 will be an update
—> Package iwl5000-firmware.noarch 0:8.83.5.1_1-62.el7 will be updated
—> Package iwl5000-firmware.noarch 0:8.83.5.1_1-62.2.el7_5 will be an update
—> Package iwl5150-firmware.noarch 0:8.24.2.2-62.el7 will be updated
—> Package iwl5150-firmware.noarch 0:8.24.2.2-62.2.el7_5 will be an update
—> Package iwl6000-firmware.noarch 0:9.221.4.1-62.el7 will be updated
—> Package iwl6000-firmware.noarch 0:9.221.4.1-62.2.el7_5 will be an update
—> Package iwl6000g2a-firmware.noarch 0:17.168.5.3-62.el7 will be updated
—> Package iwl6000g2a-firmware.noarch 0:17.168.5.3-62.2.el7_5 will be an update
—> Package iwl6000g2b-firmware.noarch 0:17.168.5.2-62.el7 will be updated
—> Package iwl6000g2b-firmware.noarch 0:17.168.5.2-62.2.el7_5 will be an update
—> Package iwl6050-firmware.noarch 0:41.28.5.1-62.el7 will be updated
—> Package iwl6050-firmware.noarch 0:41.28.5.1-62.2.el7_5 will be an update
—> Package iwl7260-firmware.noarch 0:22.0.7.0-62.el7 will be updated
—> Package iwl7260-firmware.noarch 0:22.0.7.0-62.2.el7_5 will be an update
—> Package iwl7265-firmware.noarch 0:22.0.7.0-62.el7 will be updated
—> Package iwl7265-firmware.noarch 0:22.0.7.0-62.2.el7_5 will be an update
—> Package kernel.x86_64 0:3.10.0-862.14.4.el7 will be installed
—> Package kernel-tools.x86_64 0:3.10.0-862.el7 will be updated
—> Package kernel-tools.x86_64 0:3.10.0-862.14.4.el7 will be an update
—> Package kernel-tools-libs.x86_64 0:3.10.0-862.el7 will be updated
—> Package kernel-tools-libs.x86_64 0:3.10.0-862.14.4.el7 will be an update
—> Package kexec-tools.x86_64 0:2.0.15-13.el7 will be updated
—> Package kexec-tools.x86_64 0:2.0.15-13.el7_5.2 will be an update
—> Package kpartx.x86_64 0:0.4.9-119.el7 will be updated
—> Package kpartx.x86_64 0:0.4.9-119.el7_5.1 will be an update
—> Package krb5-libs.x86_64 0:1.15.1-18.el7 will be updated
—> Package krb5-libs.x86_64 0:1.15.1-19.el7 will be an update
—> Package libblkid.x86_64 0:2.23.2-52.el7 will be updated
—> Package libblkid.x86_64 0:2.23.2-52.el7_5.1 will be an update
—> Package libcom_err.x86_64 0:1.42.9-11.el7 will be updated
—> Package libcom_err.x86_64 0:1.42.9-12.el7_5 will be an update
—> Package libgcc.x86_64 0:4.8.5-28.el7 will be updated
—> Package libgcc.x86_64 0:4.8.5-28.el7_5.1 will be an update
—> Package libgomp.x86_64 0:4.8.5-28.el7 will be updated
—> Package libgomp.x86_64 0:4.8.5-28.el7_5.1 will be an update
—> Package libmount.x86_64 0:2.23.2-52.el7 will be updated
—> Package libmount.x86_64 0:2.23.2-52.el7_5.1 will be an update
—> Package libmspack.x86_64 0:0.5-0.5.alpha.el7 will be updated
—> Package libmspack.x86_64 0:0.7-0.1.alpha.el7 will be an update
—> Package libss.x86_64 0:1.42.9-11.el7 will be updated
—> Package libss.x86_64 0:1.42.9-12.el7_5 will be an update
—> Package libstdc++.x86_64 0:4.8.5-28.el7 will be updated
—> Package libstdc++.x86_64 0:4.8.5-28.el7_5.1 will be an update
—> Package libuuid.x86_64 0:2.23.2-52.el7 will be updated
—> Package libuuid.x86_64 0:2.23.2-52.el7_5.1 will be an update
—> Package linux-firmware.noarch 0:20180220-62.git6d51311.el7 will be updated
—> Package linux-firmware.noarch 0:20180220-62.2.git6d51311.el7_5 will be an update
—> Package mariadb-libs.x86_64 1:5.5.56-2.el7 will be updated
—> Package mariadb-libs.x86_64 1:5.5.60-1.el7_5 will be an update
—> Package microcode_ctl.x86_64 2:2.1-29.el7 will be updated
—> Package microcode_ctl.x86_64 2:2.1-29.16.el7_5 will be an update
—> Package nspr.x86_64 0:4.17.0-1.el7 will be updated
—> Package nspr.x86_64 0:4.19.0-1.el7_5 will be an update
—> Package nss.x86_64 0:3.34.0-4.el7 will be updated
—> Package nss.x86_64 0:3.36.0-7.el7_5 will be an update
—> Package nss-softokn.x86_64 0:3.34.0-2.el7 will be updated
—> Package nss-softokn.x86_64 0:3.36.0-5.el7_5 will be an update
—> Package nss-softokn-freebl.x86_64 0:3.34.0-2.el7 will be updated
—> Package nss-softokn-freebl.x86_64 0:3.36.0-5.el7_5 will be an update
—> Package nss-sysinit.x86_64 0:3.34.0-4.el7 will be updated
—> Package nss-sysinit.x86_64 0:3.36.0-7.el7_5 will be an update
—> Package nss-tools.x86_64 0:3.34.0-4.el7 will be updated
—> Package nss-tools.x86_64 0:3.36.0-7.el7_5 will be an update
—> Package nss-util.x86_64 0:3.34.0-2.el7 will be updated
—> Package nss-util.x86_64 0:3.36.0-1.el7_5 will be an update
—> Package open-vm-tools.x86_64 0:10.1.10-3.el7 will be updated
—> Package open-vm-tools.x86_64 0:10.1.10-3.el7_5.1 will be an update
—> Package openldap.x86_64 0:2.4.44-13.el7 will be updated
—> Package openldap.x86_64 0:2.4.44-15.el7_5 will be an update
—> Package procps-ng.x86_64 0:3.3.10-17.el7 will be updated
—> Package procps-ng.x86_64 0:3.3.10-17.el7_5.2 will be an update
—> Package python.x86_64 0:2.7.5-68.el7 will be updated
—> Package python.x86_64 0:2.7.5-69.el7_5 will be an update
—> Package python-firewall.noarch 0:0.4.4.4-14.el7 will be updated
—> Package python-firewall.noarch 0:0.4.4.4-15.el7_5 will be an update
—> Package python-libs.x86_64 0:2.7.5-68.el7 will be updated
—> Package python-libs.x86_64 0:2.7.5-69.el7_5 will be an update
—> Package python-perf.x86_64 0:3.10.0-862.el7 will be updated
—> Package python-perf.x86_64 0:3.10.0-862.14.4.el7 will be an update
—> Package rsyslog.x86_64 0:8.24.0-16.el7 will be updated
—> Package rsyslog.x86_64 0:8.24.0-16.el7_5.4 will be an update
—> Package selinux-policy.noarch 0:3.13.1-192.el7 will be updated
—> Package selinux-policy.noarch 0:3.13.1-192.el7_5.6 will be an update
—> Package selinux-policy-targeted.noarch 0:3.13.1-192.el7 will be updated
—> Package selinux-policy-targeted.noarch 0:3.13.1-192.el7_5.6 will be an update
—> Package sudo.x86_64 0:1.8.19p2-13.el7 will be updated
—> Package sudo.x86_64 0:1.8.19p2-14.el7_5 will be an update
—> Package systemd.x86_64 0:219-57.el7 will be updated
—> Package systemd.x86_64 0:219-57.el7_5.3 will be an update
—> Package systemd-libs.x86_64 0:219-57.el7 will be updated
—> Package systemd-libs.x86_64 0:219-57.el7_5.3 will be an update
—> Package systemd-sysv.x86_64 0:219-57.el7 will be updated
—> Package systemd-sysv.x86_64 0:219-57.el7_5.3 will be an update
—> Package tuned.noarch 0:2.9.0-1.el7 will be updated
—> Package tuned.noarch 0:2.9.0-1.el7_5.2 will be an update
—> Package tzdata.noarch 0:2018c-1.el7 will be updated
—> Package tzdata.noarch 0:2018f-2.el7 will be an update
—> Package util-linux.x86_64 0:2.23.2-52.el7 will be updated
—> Package util-linux.x86_64 0:2.23.2-52.el7_5.1 will be an update
—> Package yum-plugin-fastestmirror.noarch 0:1.1.31-45.el7 will be updated
—> Package yum-plugin-fastestmirror.noarch 0:1.1.31-46.el7_5 will be an update
Size
Installing:
kernel x86_64 3.10.0-862.14.4.el7 updates 46 M
Updating:
NetworkManager x86_64 1:1.10.2-16.el7_5 updates 1.7 M
NetworkManager-libnm x86_64 1:1.10.2-16.el7_5 updates 1.3 M
NetworkManager-team x86_64 1:1.10.2-16.el7_5 updates 161 k
NetworkManager-tui x86_64 1:1.10.2-16.el7_5 updates 235 k
audit x86_64 2.8.1-3.el7_5.1 updates 247 k
audit-libs x86_64 2.8.1-3.el7_5.1 updates 99 k
bind-libs-lite x86_64 32:9.9.4-61.el7_5.1 updates 734 k
bind-license noarch 32:9.9.4-61.el7_5.1 updates 85 k
binutils x86_64 2.27-28.base.el7_5.1 updates 5.9 M
ca-certificates noarch 2018.2.22-70.0.el7_5 updates 392 k
centos-release x86_64 7-5.1804.5.el7.centos updates 25 k
dhclient x86_64 12:4.2.5-68.el7.centos.1 updates 284 k
dhcp-common x86_64 12:4.2.5-68.el7.centos.1 updates 175 k
dhcp-libs x86_64 12:4.2.5-68.el7.centos.1 updates 131 k
dracut x86_64 033-535.el7_5.1 updates 325 k
dracut-config-rescue x86_64 033-535.el7_5.1 updates 58 k
dracut-network x86_64 033-535.el7_5.1 updates 100 k
e2fsprogs x86_64 1.42.9-12.el7_5 updates 699 k
e2fsprogs-libs x86_64 1.42.9-12.el7_5 updates 167 k
firewalld noarch 0.4.4.4-15.el7_5 updates 418 k
firewalld-filesystem noarch 0.4.4.4-15.el7_5 updates 49 k
gnupg2 x86_64 2.0.22-5.el7_5 updates 1.5 M
initscripts x86_64 9.49.41-1.el7_5.2 updates 437 k
iptables x86_64 1.4.21-24.1.el7_5 updates 432 k
iwl100-firmware noarch 39.31.5.1-62.2.el7_5 updates 155 k
iwl1000-firmware noarch 1:39.31.5.1-62.2.el7_5 updates 218 k
iwl105-firmware noarch 18.168.6.1-62.2.el7_5 updates 239 k
iwl135-firmware noarch 18.168.6.1-62.2.el7_5 updates 248 k
iwl2000-firmware noarch 18.168.6.1-62.2.el7_5 updates 242 k
iwl2030-firmware noarch 18.168.6.1-62.2.el7_5 updates 251 k
iwl3160-firmware noarch 22.0.7.0-62.2.el7_5 updates 1.6 M
iwl3945-firmware noarch 15.32.2.9-62.2.el7_5 updates 93 k
iwl4965-firmware noarch 228.61.2.24-62.2.el7_5 updates 107 k
iwl5000-firmware noarch 8.83.5.1_1-62.2.el7_5 updates 299 k
iwl5150-firmware noarch 8.24.2.2-62.2.el7_5 updates 152 k
iwl6000-firmware noarch 9.221.4.1-62.2.el7_5 updates 172 k
iwl6000g2a-firmware noarch 17.168.5.3-62.2.el7_5 updates 315 k
iwl6000g2b-firmware noarch 17.168.5.2-62.2.el7_5 updates 315 k
iwl6050-firmware noarch 41.28.5.1-62.2.el7_5 updates 248 k
iwl7260-firmware noarch 22.0.7.0-62.2.el7_5 updates 1.1 M
iwl7265-firmware noarch 22.0.7.0-62.2.el7_5 updates 5.5 M
kernel-tools x86_64 3.10.0-862.14.4.el7 updates 6.3 M
kernel-tools-libs x86_64 3.10.0-862.14.4.el7 updates 6.2 M
kexec-tools x86_64 2.0.15-13.el7_5.2 updates 341 k
kpartx x86_64 0.4.9-119.el7_5.1 updates 76 k
krb5-libs x86_64 1.15.1-19.el7 updates 747 k
libblkid x86_64 2.23.2-52.el7_5.1 updates 178 k
libcom_err x86_64 1.42.9-12.el7_5 updates 41 k
libgcc x86_64 4.8.5-28.el7_5.1 updates 101 k
libgomp x86_64 4.8.5-28.el7_5.1 updates 156 k
libmount x86_64 2.23.2-52.el7_5.1 updates 180 k
libmspack x86_64 0.7-0.1.alpha.el7 epel 76 k
libss x86_64 1.42.9-12.el7_5 updates 45 k
libstdc++ x86_64 4.8.5-28.el7_5.1 updates 303 k
libuuid x86_64 2.23.2-52.el7_5.1 updates 81 k
linux-firmware noarch 20180220-62.2.git6d51311.el7_5 updates 57 M
mariadb-libs x86_64 1:5.5.60-1.el7_5 updates 758 k
microcode_ctl x86_64 2:2.1-29.16.el7_5 updates 1.4 M
nspr x86_64 4.19.0-1.el7_5 updates 127 k
nss x86_64 3.36.0-7.el7_5 updates 835 k
nss-softokn x86_64 3.36.0-5.el7_5 updates 315 k
nss-softokn-freebl x86_64 3.36.0-5.el7_5 updates 222 k
nss-sysinit x86_64 3.36.0-7.el7_5 updates 62 k
nss-tools x86_64 3.36.0-7.el7_5 updates 515 k
nss-util x86_64 3.36.0-1.el7_5 updates 78 k
open-vm-tools x86_64 10.1.10-3.el7_5.1 updates 672 k
openldap x86_64 2.4.44-15.el7_5 updates 355 k
procps-ng x86_64 3.3.10-17.el7_5.2 updates 290 k
python x86_64 2.7.5-69.el7_5 updates 93 k
python-firewall noarch 0.4.4.4-15.el7_5 updates 328 k
python-libs x86_64 2.7.5-69.el7_5 updates 5.6 M
python-perf x86_64 3.10.0-862.14.4.el7 updates 6.3 M
rsyslog x86_64 8.24.0-16.el7_5.4 updates 607 k
selinux-policy noarch 3.13.1-192.el7_5.6 updates 453 k
selinux-policy-targeted noarch 3.13.1-192.el7_5.6 updates 6.6 M
sudo x86_64 1.8.19p2-14.el7_5 updates 1.1 M
systemd x86_64 219-57.el7_5.3 updates 5.0 M
systemd-libs x86_64 219-57.el7_5.3 updates 402 k
systemd-sysv x86_64 219-57.el7_5.3 updates 80 k
tuned noarch 2.9.0-1.el7_5.2 updates 244 k
tzdata noarch 2018f-2.el7 updates 484 k
util-linux x86_64 2.23.2-52.el7_5.1 updates 2.0 M
yum-plugin-fastestmirror noarch 1.1.31-46.el7_5 updates 33 k
Transaction Summary
Install 1 Package
Upgrade 83 Packages
Total download size: 179 M
Delta RPMs disabled because /usr/bin/applydeltarpm not installed.
(1/84): NetworkManager-libnm-1.10.2-16.el7_5.x86_64.rpm | 1.3 MB 00:00
(2/84): NetworkManager-1.10.2-16.el7_5.x86_64.rpm | 1.7 MB 00:00
(3/84): NetworkManager-team-1.10.2-16.el7_5.x86_64.rpm | 161 kB 00:00
(4/84): NetworkManager-tui-1.10.2-16.el7_5.x86_64.rpm | 235 kB 00:00
(5/84): audit-libs-2.8.1-3.el7_5.1.x86_64.rpm | 99 kB 00:00
(6/84): audit-2.8.1-3.el7_5.1.x86_64.rpm | 247 kB 00:00
(7/84): bind-license-9.9.4-61.el7_5.1.noarch.rpm | 85 kB 00:00
(8/84): bind-libs-lite-9.9.4-61.el7_5.1.x86_64.rpm | 734 kB 00:00
(9/84): ca-certificates-2018.2.22-70.0.el7_5.noarch.rpm | 392 kB 00:00
(10/84): centos-release-7-5.1804.5.el7.centos.x86_64.rpm | 25 kB 00:00
(11/84): binutils-2.27-28.base.el7_5.1.x86_64.rpm | 5.9 MB 00:01
(12/84): dhclient-4.2.5-68.el7.centos.1.x86_64.rpm | 284 kB 00:00
(13/84): dhcp-common-4.2.5-68.el7.centos.1.x86_64.rpm | 175 kB 00:00
(14/84): dhcp-libs-4.2.5-68.el7.centos.1.x86_64.rpm | 131 kB 00:00
(15/84): dracut-config-rescue-033-535.el7_5.1.x86_64.rpm | 58 kB 00:00
(16/84): dracut-033-535.el7_5.1.x86_64.rpm | 325 kB 00:00
(17/84): dracut-network-033-535.el7_5.1.x86_64.rpm | 100 kB 00:00
(18/84): e2fsprogs-libs-1.42.9-12.el7_5.x86_64.rpm | 167 kB 00:00
(19/84): e2fsprogs-1.42.9-12.el7_5.x86_64.rpm | 699 kB 00:00
(20/84): firewalld-filesystem-0.4.4.4-15.el7_5.noarch.rpm | 49 kB 00:00
(21/84): firewalld-0.4.4.4-15.el7_5.noarch.rpm | 418 kB 00:00
(22/84): initscripts-9.49.41-1.el7_5.2.x86_64.rpm | 437 kB 00:00
(23/84): gnupg2-2.0.22-5.el7_5.x86_64.rpm | 1.5 MB 00:00
(24/84): iwl100-firmware-39.31.5.1-62.2.el7_5.noarch.rpm | 155 kB 00:00
(25/84): iptables-1.4.21-24.1.el7_5.x86_64.rpm | 432 kB 00:00
(26/84): iwl1000-firmware-39.31.5.1-62.2.el7_5.noarch.rpm | 218 kB 00:00
(27/84): iwl105-firmware-18.168.6.1-62.2.el7_5.noarch.rpm | 239 kB 00:00
(28/84): iwl135-firmware-18.168.6.1-62.2.el7_5.noarch.rpm | 248 kB 00:00
(29/84): iwl2000-firmware-18.168.6.1-62.2.el7_5.noarch.rpm | 242 kB 00:00
(30/84): iwl2030-firmware-18.168.6.1-62.2.el7_5.noarch.rpm | 251 kB 00:00
(31/84): iwl3945-firmware-15.32.2.9-62.2.el7_5.noarch.rpm | 93 kB 00:00
(32/84): iwl4965-firmware-228.61.2.24-62.2.el7_5.noarch.rp | 107 kB 00:00
(33/84): iwl5000-firmware-8.83.5.1_1-62.2.el7_5.noarch.rpm | 299 kB 00:00
(34/84): iwl3160-firmware-22.0.7.0-62.2.el7_5.noarch.rpm | 1.6 MB 00:00
(35/84): iwl5150-firmware-8.24.2.2-62.2.el7_5.noarch.rpm | 152 kB 00:00
(36/84): iwl6000-firmware-9.221.4.1-62.2.el7_5.noarch.rpm | 172 kB 00:00
(37/84): iwl6000g2a-firmware-17.168.5.3-62.2.el7_5.noarch. | 315 kB 00:00
(38/84): iwl6000g2b-firmware-17.168.5.2-62.2.el7_5.noarch. | 315 kB 00:00
(39/84): iwl6050-firmware-41.28.5.1-62.2.el7_5.noarch.rpm | 248 kB 00:00
(40/84): iwl7260-firmware-22.0.7.0-62.2.el7_5.noarch.rpm | 1.1 MB 00:00
(41/84): iwl7265-firmware-22.0.7.0-62.2.el7_5.noarch.rpm | 5.5 MB 00:01
(42/84): kernel-tools-3.10.0-862.14.4.el7.x86_64.rpm | 6.3 MB 00:01
(43/84): kernel-tools-libs-3.10.0-862.14.4.el7.x86_64.rpm | 6.2 MB 00:00
(44/84): kexec-tools-2.0.15-13.el7_5.2.x86_64.rpm | 341 kB 00:00
(45/84): kpartx-0.4.9-119.el7_5.1.x86_64.rpm | 76 kB 00:00
(46/84): krb5-libs-1.15.1-19.el7.x86_64.rpm | 747 kB 00:00
(47/84): libblkid-2.23.2-52.el7_5.1.x86_64.rpm | 178 kB 00:00
(48/84): libcom_err-1.42.9-12.el7_5.x86_64.rpm | 41 kB 00:00
(49/84): libgcc-4.8.5-28.el7_5.1.x86_64.rpm | 101 kB 00:00
(50/84): libgomp-4.8.5-28.el7_5.1.x86_64.rpm | 156 kB 00:00
(51/84): libmount-2.23.2-52.el7_5.1.x86_64.rpm | 180 kB 00:00
warning: /var/cache/yum/x86_64/7/epel/packages/libmspack-0.7-0.1.alpha.el7.x86_64.rpm: Header V3 RSA/SHA256 Signature, key ID 352c64e5: NOKEY
Public key for libmspack-0.7-0.1.alpha.el7.x86_64.rpm is not installed
(52/84): libmspack-0.7-0.1.alpha.el7.x86_64.rpm | 76 kB 00:00
(53/84): libss-1.42.9-12.el7_5.x86_64.rpm | 45 kB 00:00
(54/84): libstdc+±4.8.5-28.el7_5.1.x86_64.rpm | 303 kB 00:00
(55/84): libuuid-2.23.2-52.el7_5.1.x86_64.rpm | 81 kB 00:00
(56/84): kernel-3.10.0-862.14.4.el7.x86_64.rpm | 46 MB 00:11
(57/84): linux-firmware-20180220-62.2.git6d51311.el7_5.noa | 57 MB 00:06
(58/84): mariadb-libs-5.5.60-1.el7_5.x86_64.rpm | 758 kB 00:00
(59/84): nspr-4.19.0-1.el7_5.x86_64.rpm | 127 kB 00:00
(60/84): microcode_ctl-2.1-29.16.el7_5.x86_64.rpm | 1.4 MB 00:00
(61/84): nss-softokn-3.36.0-5.el7_5.x86_64.rpm | 315 kB 00:00
(62/84): nss-3.36.0-7.el7_5.x86_64.rpm | 835 kB 00:00
(63/84): nss-sysinit-3.36.0-7.el7_5.x86_64.rpm | 62 kB 00:00
(64/84): nss-softokn-freebl-3.36.0-5.el7_5.x86_64.rpm | 222 kB 00:00
(65/84): nss-util-3.36.0-1.el7_5.x86_64.rpm | 78 kB 00:00
(66/84): nss-tools-3.36.0-7.el7_5.x86_64.rpm | 515 kB 00:00
(67/84): open-vm-tools-10.1.10-3.el7_5.1.x86_64.rpm | 672 kB 00:00
(68/84): openldap-2.4.44-15.el7_5.x86_64.rpm | 355 kB 00:00
(69/84): procps-ng-3.3.10-17.el7_5.2.x86_64.rpm | 290 kB 00:00
(70/84): python-2.7.5-69.el7_5.x86_64.rpm | 93 kB 00:00
(71/84): python-firewall-0.4.4.4-15.el7_5.noarch.rpm | 328 kB 00:00
(72/84): python-libs-2.7.5-69.el7_5.x86_64.rpm | 5.6 MB 00:01
(73/84): python-perf-3.10.0-862.14.4.el7.x86_64.rpm | 6.3 MB 00:01
(74/84): rsyslog-8.24.0-16.el7_5.4.x86_64.rpm | 607 kB 00:00
(75/84): selinux-policy-3.13.1-192.el7_5.6.noarch.rpm | 453 kB 00:00
(76/84): sudo-1.8.19p2-14.el7_5.x86_64.rpm | 1.1 MB 00:00
(77/84): selinux-policy-targeted-3.13.1-192.el7_5.6.noarch | 6.6 MB 00:00
(78/84): systemd-libs-219-57.el7_5.3.x86_64.rpm | 402 kB 00:00
(79/84): systemd-219-57.el7_5.3.x86_64.rpm | 5.0 MB 00:00
(80/84): systemd-sysv-219-57.el7_5.3.x86_64.rpm | 80 kB 00:00
(81/84): tuned-2.9.0-1.el7_5.2.noarch.rpm | 244 kB 00:00
(82/84): tzdata-2018f-2.el7.noarch.rpm | 484 kB 00:00
(83/84): yum-plugin-fastestmirror-1.1.31-46.el7_5.noarch.r | 33 kB 00:00
(84/84): util-linux-2.23.2-52.el7_5.1.x86_64.rpm | 2.0 MB 00:00
Total 7.7 MB/s | 179 MB 00:23
Retrieving key from file:///etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-7
Importing GPG key 0x352C64E5:
Userid : “Fedora EPEL (7) epel@fedoraproject.org”
Fingerprint: 91e9 7d7c 4a5e 96f1 7f3e 888f 6a2f aea2 352c 64e5
Package : epel-release-7-11.noarch (@extras)
Running transaction
Updating : nspr-4.19.0-1.el7_5.x86_64 1/167
Updating : libgcc-4.8.5-28.el7_5.1.x86_64 2/167
Updating : systemd-libs-219-57.el7_5.3.x86_64 3/167
Updating : nss-util-3.36.0-1.el7_5.x86_64 4/167
Updating : libuuid-2.23.2-52.el7_5.1.x86_64 5/167
Updating : audit-libs-2.8.1-3.el7_5.1.x86_64 6/167
Updating : libcom_err-1.42.9-12.el7_5.x86_64 7/167
Updating : libblkid-2.23.2-52.el7_5.1.x86_64 8/167
Updating : centos-release-7-5.1804.5.el7.centos.x86_64 9/167
Updating : libmount-2.23.2-52.el7_5.1.x86_64 10/167
Updating : systemd-219-57.el7_5.3.x86_64 11/167
Updating : util-linux-2.23.2-52.el7_5.1.x86_64 12/167
Updating : krb5-libs-1.15.1-19.el7.x86_64 13/167
Updating : procps-ng-3.3.10-17.el7_5.2.x86_64 14/167
Updating : initscripts-9.49.41-1.el7_5.2.x86_64 15/167
Updating : libstdc+±4.8.5-28.el7_5.1.x86_64 16/167
Updating : python-libs-2.7.5-69.el7_5.x86_64 17/167
Updating : python-2.7.5-69.el7_5.x86_64 18/167
Updating : python-firewall-0.4.4.4-15.el7_5.noarch 19/167
Updating : systemd-sysv-219-57.el7_5.3.x86_64 20/167
Updating : python-perf-3.10.0-862.14.4.el7.x86_64 21/167
Updating : libss-1.42.9-12.el7_5.x86_64 22/167
Updating : e2fsprogs-libs-1.42.9-12.el7_5.x86_64 23/167
Updating : nss-softokn-freebl-3.36.0-5.el7_5.x86_64 24/167
Updating : nss-softokn-3.36.0-5.el7_5.x86_64 25/167
Updating : nss-3.36.0-7.el7_5.x86_64 26/167
Updating : nss-sysinit-3.36.0-7.el7_5.x86_64 27/167
Updating : 1:NetworkManager-libnm-1.10.2-16.el7_5.x86_64 28/167
Updating : 1:NetworkManager-1.10.2-16.el7_5.x86_64 29/167
Updating : nss-tools-3.36.0-7.el7_5.x86_64 30/167
Updating : openldap-2.4.44-15.el7_5.x86_64 31/167
Updating : 12:dhcp-libs-4.2.5-68.el7.centos.1.x86_64 32/167
Updating : 12:dhcp-common-4.2.5-68.el7.centos.1.x86_64 33/167
Updating : libmspack-0.7-0.1.alpha.el7.x86_64 34/167
Updating : selinux-policy-3.13.1-192.el7_5.6.noarch 35/167
Updating : kernel-tools-libs-3.10.0-862.14.4.el7.x86_64 36/167
Updating : firewalld-filesystem-0.4.4.4-15.el7_5.noarch 37/167
Updating : kpartx-0.4.9-119.el7_5.1.x86_64 38/167
Updating : dracut-033-535.el7_5.1.x86_64 39/167
Updating : iptables-1.4.21-24.1.el7_5.x86_64 40/167
Updating : 32:bind-license-9.9.4-61.el7_5.1.noarch 41/167
Updating : 32:bind-libs-lite-9.9.4-61.el7_5.1.x86_64 42/167
Updating : 12:dhclient-4.2.5-68.el7.centos.1.x86_64 43/167
Updating : dracut-network-033-535.el7_5.1.x86_64 44/167
Updating : linux-firmware-20180220-62.2.git6d51311.el7_5.noarch 45/167
Installing : kernel-3.10.0-862.14.4.el7.x86_64 46/167
Updating : kexec-tools-2.0.15-13.el7_5.2.x86_64 47/167
Updating : firewalld-0.4.4.4-15.el7_5.noarch 48/167
Updating : dracut-config-rescue-033-535.el7_5.1.x86_64 49/167
Updating : kernel-tools-3.10.0-862.14.4.el7.x86_64 50/167
Updating : selinux-policy-targeted-3.13.1-192.el7_5.6.noarch 51/167
Updating : open-vm-tools-10.1.10-3.el7_5.1.x86_64 52/167
Updating : sudo-1.8.19p2-14.el7_5.x86_64 53/167
Updating : gnupg2-2.0.22-5.el7_5.x86_64 54/167
Updating : 1:NetworkManager-tui-1.10.2-16.el7_5.x86_64 55/167
Updating : 1:NetworkManager-team-1.10.2-16.el7_5.x86_64 56/167
Updating : e2fsprogs-1.42.9-12.el7_5.x86_64 57/167
Updating : tuned-2.9.0-1.el7_5.2.noarch 58/167
Updating : audit-2.8.1-3.el7_5.1.x86_64 59/167
Updating : 1:mariadb-libs-5.5.60-1.el7_5.x86_64 60/167
Updating : rsyslog-8.24.0-16.el7_5.4.x86_64 61/167
Updating : 2:microcode_ctl-2.1-29.16.el7_5.x86_64 62/167
Updating : iwl6000g2a-firmware-17.168.5.3-62.2.el7_5.noarch 63/167
Updating : iwl5000-firmware-8.83.5.1_1-62.2.el7_5.noarch 64/167
Updating : tzdata-2018f-2.el7.noarch 65/167
Updating : iwl135-firmware-18.168.6.1-62.2.el7_5.noarch 66/167
Updating : iwl6050-firmware-41.28.5.1-62.2.el7_5.noarch 67/167
Updating : iwl7260-firmware-22.0.7.0-62.2.el7_5.noarch 68/167
Updating : iwl2000-firmware-18.168.6.1-62.2.el7_5.noarch 69/167
Updating : iwl105-firmware-18.168.6.1-62.2.el7_5.noarch 70/167
Updating : binutils-2.27-28.base.el7_5.1.x86_64 71/167
Updating : iwl3945-firmware-15.32.2.9-62.2.el7_5.noarch 72/167
Updating : iwl6000g2b-firmware-17.168.5.2-62.2.el7_5.noarch 73/167
Updating : iwl3160-firmware-22.0.7.0-62.2.el7_5.noarch 74/167
Updating : iwl5150-firmware-8.24.2.2-62.2.el7_5.noarch 75/167
Updating : iwl100-firmware-39.31.5.1-62.2.el7_5.noarch 76/167
Updating : 1:iwl1000-firmware-39.31.5.1-62.2.el7_5.noarch 77/167
Updating : ca-certificates-2018.2.22-70.0.el7_5.noarch 78/167
Updating : iwl4965-firmware-228.61.2.24-62.2.el7_5.noarch 79/167
Updating : iwl6000-firmware-9.221.4.1-62.2.el7_5.noarch 80/167
Updating : yum-plugin-fastestmirror-1.1.31-46.el7_5.noarch 81/167
Updating : iwl2030-firmware-18.168.6.1-62.2.el7_5.noarch 82/167
Updating : libgomp-4.8.5-28.el7_5.1.x86_64 83/167
Updating : iwl7265-firmware-22.0.7.0-62.2.el7_5.noarch 84/167
Cleanup : firewalld-0.4.4.4-14.el7.noarch 85/167
Cleanup : tuned-2.9.0-1.el7.noarch 86/167
Cleanup : python-firewall-0.4.4.4-14.el7.noarch 87/167
Cleanup : dracut-config-rescue-033-535.el7.x86_64 88/167
Cleanup : selinux-policy-targeted-3.13.1-192.el7.noarch 89/167
Cleanup : selinux-policy-3.13.1-192.el7.noarch 90/167
Cleanup : firewalld-filesystem-0.4.4.4-14.el7.noarch 91/167
Cleanup : iwl6000g2a-firmware-17.168.5.3-62.el7.noarch 92/167
Cleanup : iwl5000-firmware-8.83.5.1_1-62.el7.noarch 93/167
Cleanup : tzdata-2018c-1.el7.noarch 94/167
Cleanup : iwl135-firmware-18.168.6.1-62.el7.noarch 95/167
Cleanup : iwl6050-firmware-41.28.5.1-62.el7.noarch 96/167
Cleanup : iwl7260-firmware-22.0.7.0-62.el7.noarch 97/167
Cleanup : iwl2000-firmware-18.168.6.1-62.el7.noarch 98/167
Cleanup : iwl105-firmware-18.168.6.1-62.el7.noarch 99/167
Cleanup : iwl3945-firmware-15.32.2.9-62.el7.noarch 100/167
Cleanup : iwl6000g2b-firmware-17.168.5.2-62.el7.noarch 101/167
Cleanup : iwl3160-firmware-22.0.7.0-62.el7.noarch 102/167
Cleanup : iwl5150-firmware-8.24.2.2-62.el7.noarch 103/167
Cleanup : iwl100-firmware-39.31.5.1-62.el7.noarch 104/167
Cleanup : 1:iwl1000-firmware-39.31.5.1-62.el7.noarch 105/167
Cleanup : ca-certificates-2017.2.20-71.el7.noarch 106/167
Cleanup : iwl4965-firmware-228.61.2.24-62.el7.noarch 107/167
Cleanup : iwl6000-firmware-9.221.4.1-62.el7.noarch 108/167
Cleanup : yum-plugin-fastestmirror-1.1.31-45.el7.noarch 109/167
Cleanup : iwl2030-firmware-18.168.6.1-62.el7.noarch 110/167
Cleanup : iwl7265-firmware-22.0.7.0-62.el7.noarch 111/167
Cleanup : linux-firmware-20180220-62.git6d51311.el7.noarch 112/167
Cleanup : 1:NetworkManager-tui-1.10.2-13.el7.x86_64 113/167
Cleanup : e2fsprogs-1.42.9-11.el7.x86_64 114/167
Cleanup : open-vm-tools-10.1.10-3.el7.x86_64 115/167
Cleanup : audit-2.8.1-3.el7.x86_64 116/167
Cleanup : rsyslog-8.24.0-16.el7.x86_64 117/167
Cleanup : kexec-tools-2.0.15-13.el7.x86_64 118/167
Cleanup : dracut-network-033-535.el7.x86_64 119/167
Cleanup : 12:dhclient-4.2.5-68.el7.centos.x86_64 120/167
Cleanup : systemd-sysv-219-57.el7.x86_64 121/167
Cleanup : dracut-033-535.el7.x86_64 122/167
Cleanup : initscripts-9.49.41-1.el7.x86_64 123/167
Cleanup : util-linux-2.23.2-52.el7.x86_64 124/167
Cleanup : 32:bind-libs-lite-9.9.4-61.el7.x86_64 125/167
Cleanup : python-perf-3.10.0-862.el7.x86_64 126/167
Cleanup : 1:NetworkManager-team-1.10.2-13.el7.x86_64 127/167
Cleanup : 1:NetworkManager-1.10.2-13.el7.x86_64 128/167
Cleanup : 1:NetworkManager-libnm-1.10.2-13.el7.x86_64 129/167
Cleanup : sudo-1.8.19p2-13.el7.x86_64 130/167
Cleanup : 12:dhcp-common-4.2.5-68.el7.centos.x86_64 131/167
Cleanup : 12:dhcp-libs-4.2.5-68.el7.centos.x86_64 132/167
Cleanup : python-2.7.5-68.el7.x86_64 133/167
Cleanup : krb5-libs-1.15.1-18.el7.x86_64 134/167
Cleanup : procps-ng-3.3.10-17.el7.x86_64 135/167
Cleanup : e2fsprogs-libs-1.42.9-11.el7.x86_64 136/167
Cleanup : libss-1.42.9-11.el7.x86_64 137/167
Cleanup : 2:microcode_ctl-2.1-29.el7.x86_64 138/167
Cleanup : systemd-219-57.el7.x86_64 139/167
Cleanup : libmount-2.23.2-52.el7.x86_64 140/167
Cleanup : libblkid-2.23.2-52.el7.x86_64 141/167
Cleanup : systemd-libs-219-57.el7.x86_64 142/167
Cleanup : gnupg2-2.0.22-4.el7.x86_64 143/167
Cleanup : openldap-2.4.44-13.el7.x86_64 144/167
Cleanup : nss-tools-3.34.0-4.el7.x86_64 145/167
Cleanup : nss-sysinit-3.34.0-4.el7.x86_64 146/167
Cleanup : nss-3.34.0-4.el7.x86_64 147/167
Cleanup : nss-softokn-3.34.0-2.el7.x86_64 148/167
Cleanup : nss-softokn-freebl-3.34.0-2.el7.x86_64 149/167
Cleanup : nss-util-3.34.0-2.el7.x86_64 150/167
Cleanup : 1:mariadb-libs-5.5.56-2.el7.x86_64 151/167
Cleanup : libstdc+±4.8.5-28.el7.x86_64 152/167
Cleanup : kernel-tools-3.10.0-862.el7.x86_64 153/167
Cleanup : centos-release-7-5.1804.el7.centos.x86_64 154/167
Cleanup : 32:bind-license-9.9.4-61.el7.noarch 155/167
Cleanup : kernel-tools-libs-3.10.0-862.el7.x86_64 156/167
Cleanup : libgcc-4.8.5-28.el7.x86_64 157/167
Cleanup : nspr-4.17.0-1.el7.x86_64 158/167
Cleanup : libuuid-2.23.2-52.el7.x86_64 159/167
Cleanup : audit-libs-2.8.1-3.el7.x86_64 160/167
Cleanup : libcom_err-1.42.9-11.el7.x86_64 161/167
Cleanup : python-libs-2.7.5-68.el7.x86_64 162/167
Cleanup : kpartx-0.4.9-119.el7.x86_64 163/167
Cleanup : libmspack-0.5-0.5.alpha.el7.x86_64 164/167
Cleanup : iptables-1.4.21-24.el7.x86_64 165/167
Cleanup : binutils-2.27-27.base.el7.x86_64 166/167
Cleanup : libgomp-4.8.5-28.el7.x86_64 167/167
Verifying : linux-firmware-20180220-62.2.git6d51311.el7_5.noarch 1/167
Verifying : iwl7265-firmware-22.0.7.0-62.2.el7_5.noarch 2/167
Verifying : libgomp-4.8.5-28.el7_5.1.x86_64 3/167
Verifying : 1:NetworkManager-tui-1.10.2-16.el7_5.x86_64 4/167
Verifying : selinux-policy-targeted-3.13.1-192.el7_5.6.noarch 5/167
Verifying : 12:dhcp-libs-4.2.5-68.el7.centos.1.x86_64 6/167
Verifying : openldap-2.4.44-15.el7_5.x86_64 7/167
Verifying : 32:bind-license-9.9.4-61.el7_5.1.noarch 8/167
Verifying : iwl2030-firmware-18.168.6.1-62.2.el7_5.noarch 9/167
Verifying : dracut-config-rescue-033-535.el7_5.1.x86_64 10/167
Verifying : iptables-1.4.21-24.1.el7_5.x86_64 11/167
Verifying : systemd-libs-219-57.el7_5.3.x86_64 12/167
Verifying : libcom_err-1.42.9-12.el7_5.x86_64 13/167
Verifying : nss-sysinit-3.36.0-7.el7_5.x86_64 14/167
Verifying : python-firewall-0.4.4.4-15.el7_5.noarch 15/167
Verifying : util-linux-2.23.2-52.el7_5.1.x86_64 16/167
Verifying : dracut-network-033-535.el7_5.1.x86_64 17/167
Verifying : 1:NetworkManager-1.10.2-16.el7_5.x86_64 18/167
Verifying : yum-plugin-fastestmirror-1.1.31-46.el7_5.noarch 19/167
Verifying : open-vm-tools-10.1.10-3.el7_5.1.x86_64 20/167
Verifying : kpartx-0.4.9-119.el7_5.1.x86_64 21/167
Verifying : nss-util-3.36.0-1.el7_5.x86_64 22/167
Verifying : 32:bind-libs-lite-9.9.4-61.el7_5.1.x86_64 23/167
Verifying : 12:dhcp-common-4.2.5-68.el7.centos.1.x86_64 24/167
Verifying : tuned-2.9.0-1.el7_5.2.noarch 25/167
Verifying : kernel-tools-3.10.0-862.14.4.el7.x86_64 26/167
Verifying : centos-release-7-5.1804.5.el7.centos.x86_64 27/167
Verifying : e2fsprogs-1.42.9-12.el7_5.x86_64 28/167
Verifying : iwl6000-firmware-9.221.4.1-62.2.el7_5.noarch 29/167
Verifying : libuuid-2.23.2-52.el7_5.1.x86_64 30/167
Verifying : libgcc-4.8.5-28.el7_5.1.x86_64 31/167
Verifying : iwl4965-firmware-228.61.2.24-62.2.el7_5.noarch 32/167
Verifying : systemd-sysv-219-57.el7_5.3.x86_64 33/167
Verifying : rsyslog-8.24.0-16.el7_5.4.x86_64 34/167
Verifying : audit-libs-2.8.1-3.el7_5.1.x86_64 35/167
Verifying : python-2.7.5-69.el7_5.x86_64 36/167
Verifying : dracut-033-535.el7_5.1.x86_64 37/167
Verifying : ca-certificates-2018.2.22-70.0.el7_5.noarch 38/167
Verifying : firewalld-filesystem-0.4.4.4-15.el7_5.noarch 39/167
Verifying : sudo-1.8.19p2-14.el7_5.x86_64 40/167
Verifying : 1:NetworkManager-team-1.10.2-16.el7_5.x86_64 41/167
Verifying : 1:iwl1000-firmware-39.31.5.1-62.2.el7_5.noarch 42/167
Verifying : 1:mariadb-libs-5.5.60-1.el7_5.x86_64 43/167
Verifying : kernel-3.10.0-862.14.4.el7.x86_64 44/167
Verifying : iwl100-firmware-39.31.5.1-62.2.el7_5.noarch 45/167
Verifying : iwl5150-firmware-8.24.2.2-62.2.el7_5.noarch 46/167
Verifying : iwl3160-firmware-22.0.7.0-62.2.el7_5.noarch 47/167
Verifying : gnupg2-2.0.22-5.el7_5.x86_64 48/167
Verifying : libss-1.42.9-12.el7_5.x86_64 49/167
Verifying : python-libs-2.7.5-69.el7_5.x86_64 50/167
Verifying : e2fsprogs-libs-1.42.9-12.el7_5.x86_64 51/167
Verifying : iwl6000g2b-firmware-17.168.5.2-62.2.el7_5.noarch 52/167
Verifying : python-perf-3.10.0-862.14.4.el7.x86_64 53/167
Verifying : iwl3945-firmware-15.32.2.9-62.2.el7_5.noarch 54/167
Verifying : systemd-219-57.el7_5.3.x86_64 55/167
Verifying : binutils-2.27-28.base.el7_5.1.x86_64 56/167
Verifying : procps-ng-3.3.10-17.el7_5.2.x86_64 57/167
Verifying : 2:microcode_ctl-2.1-29.16.el7_5.x86_64 58/167
Verifying : nss-softokn-freebl-3.36.0-5.el7_5.x86_64 59/167
Verifying : libblkid-2.23.2-52.el7_5.1.x86_64 60/167
Verifying : nspr-4.19.0-1.el7_5.x86_64 61/167
Verifying : firewalld-0.4.4.4-15.el7_5.noarch 62/167
Verifying : iwl105-firmware-18.168.6.1-62.2.el7_5.noarch 63/167
Verifying : nss-softokn-3.36.0-5.el7_5.x86_64 64/167
Verifying : kernel-tools-libs-3.10.0-862.14.4.el7.x86_64 65/167
Verifying : iwl2000-firmware-18.168.6.1-62.2.el7_5.noarch 66/167
Verifying : iwl7260-firmware-22.0.7.0-62.2.el7_5.noarch 67/167
Verifying : audit-2.8.1-3.el7_5.1.x86_64 68/167
Verifying : nss-3.36.0-7.el7_5.x86_64 69/167
Verifying : 12:dhclient-4.2.5-68.el7.centos.1.x86_64 70/167
Verifying : initscripts-9.49.41-1.el7_5.2.x86_64 71/167
Verifying : krb5-libs-1.15.1-19.el7.x86_64 72/167
Verifying : iwl6050-firmware-41.28.5.1-62.2.el7_5.noarch 73/167
Verifying : iwl135-firmware-18.168.6.1-62.2.el7_5.noarch 74/167
Verifying : 1:NetworkManager-libnm-1.10.2-16.el7_5.x86_64 75/167
Verifying : libmount-2.23.2-52.el7_5.1.x86_64 76/167
Verifying : kexec-tools-2.0.15-13.el7_5.2.x86_64 77/167
Verifying : selinux-policy-3.13.1-192.el7_5.6.noarch 78/167
Verifying : libmspack-0.7-0.1.alpha.el7.x86_64 79/167
Verifying : tzdata-2018f-2.el7.noarch 80/167
Verifying : iwl5000-firmware-8.83.5.1_1-62.2.el7_5.noarch 81/167
Verifying : iwl6000g2a-firmware-17.168.5.3-62.2.el7_5.noarch 82/167
Verifying : nss-tools-3.36.0-7.el7_5.x86_64 83/167
Verifying : libstdc+±4.8.5-28.el7_5.1.x86_64 84/167
Verifying : python-libs-2.7.5-68.el7.x86_64 85/167
Verifying : nss-sysinit-3.34.0-4.el7.x86_64 86/167
Verifying : iwl5150-firmware-8.24.2.2-62.el7.noarch 87/167
Verifying : libgomp-4.8.5-28.el7.x86_64 88/167
Verifying : libstdc+±4.8.5-28.el7.x86_64 89/167
Verifying : iwl6000g2b-firmware-17.168.5.2-62.el7.noarch 90/167
Verifying : 12:dhclient-4.2.5-68.el7.centos.x86_64 91/167
Verifying : iwl6000-firmware-9.221.4.1-62.el7.noarch 92/167
Verifying : 1:iwl1000-firmware-39.31.5.1-62.el7.noarch 93/167
Verifying : 2:microcode_ctl-2.1-29.el7.x86_64 94/167
Verifying : libgcc-4.8.5-28.el7.x86_64 95/167
Verifying : kexec-tools-2.0.15-13.el7.x86_64 96/167
Verifying : centos-release-7-5.1804.el7.centos.x86_64 97/167
Verifying : linux-firmware-20180220-62.git6d51311.el7.noarch 98/167
Verifying : dracut-network-033-535.el7.x86_64 99/167
Verifying : iwl7265-firmware-22.0.7.0-62.el7.noarch 100/167
Verifying : selinux-policy-3.13.1-192.el7.noarch 101/167
Verifying : firewalld-0.4.4.4-14.el7.noarch 102/167
Verifying : iwl6000g2a-firmware-17.168.5.3-62.el7.noarch 103/167
Verifying : dracut-033-535.el7.x86_64 104/167
Verifying : selinux-policy-targeted-3.13.1-192.el7.noarch 105/167
Verifying : util-linux-2.23.2-52.el7.x86_64 106/167
Verifying : systemd-sysv-219-57.el7.x86_64 107/167
Verifying : 12:dhcp-common-4.2.5-68.el7.centos.x86_64 108/167
Verifying : tzdata-2018c-1.el7.noarch 109/167
Verifying : nss-util-3.34.0-2.el7.x86_64 110/167
Verifying : iptables-1.4.21-24.el7.x86_64 111/167
Verifying : 32:bind-libs-lite-9.9.4-61.el7.x86_64 112/167
Verifying : gnupg2-2.0.22-4.el7.x86_64 113/167
Verifying : iwl4965-firmware-228.61.2.24-62.el7.noarch 114/167
Verifying : sudo-1.8.19p2-13.el7.x86_64 115/167
Verifying : iwl3160-firmware-22.0.7.0-62.el7.noarch 116/167
Verifying : iwl100-firmware-39.31.5.1-62.el7.noarch 117/167
Verifying : libcom_err-1.42.9-11.el7.x86_64 118/167
Verifying : iwl6050-firmware-41.28.5.1-62.el7.noarch 119/167
Verifying : e2fsprogs-libs-1.42.9-11.el7.x86_64 120/167
Verifying : iwl7260-firmware-22.0.7.0-62.el7.noarch 121/167
Verifying : binutils-2.27-27.base.el7.x86_64 122/167
Verifying : tuned-2.9.0-1.el7.noarch 123/167
Verifying : iwl135-firmware-18.168.6.1-62.el7.noarch 124/167
Verifying : 1:NetworkManager-1.10.2-13.el7.x86_64 125/167
Verifying : 1:NetworkManager-tui-1.10.2-13.el7.x86_64 126/167
Verifying : audit-2.8.1-3.el7.x86_64 127/167
Verifying : nss-softokn-3.34.0-2.el7.x86_64 128/167
Verifying : kernel-tools-libs-3.10.0-862.el7.x86_64 129/167
Verifying : 12:dhcp-libs-4.2.5-68.el7.centos.x86_64 130/167
Verifying : 32:bind-license-9.9.4-61.el7.noarch 131/167
Verifying : initscripts-9.49.41-1.el7.x86_64 132/167
Verifying : python-firewall-0.4.4.4-14.el7.noarch 133/167
Verifying : ca-certificates-2017.2.20-71.el7.noarch 134/167
Verifying : 1:NetworkManager-libnm-1.10.2-13.el7.x86_64 135/167
Verifying : libuuid-2.23.2-52.el7.x86_64 136/167
Verifying : rsyslog-8.24.0-16.el7.x86_64 137/167
Verifying : libmount-2.23.2-52.el7.x86_64 138/167
Verifying : iwl105-firmware-18.168.6.1-62.el7.noarch 139/167
Verifying : audit-libs-2.8.1-3.el7.x86_64 140/167
Verifying : openldap-2.4.44-13.el7.x86_64 141/167
Verifying : 1:NetworkManager-team-1.10.2-13.el7.x86_64 142/167
Verifying : firewalld-filesystem-0.4.4.4-14.el7.noarch 143/167
Verifying : nss-softokn-freebl-3.34.0-2.el7.x86_64 144/167
Verifying : kernel-tools-3.10.0-862.el7.x86_64 145/167
Verifying : nspr-4.17.0-1.el7.x86_64 146/167
Verifying : nss-tools-3.34.0-4.el7.x86_64 147/167
Verifying : iwl2000-firmware-18.168.6.1-62.el7.noarch 148/167
Verifying : iwl2030-firmware-18.168.6.1-62.el7.noarch 149/167
Verifying : python-2.7.5-68.el7.x86_64 150/167
Verifying : dracut-config-rescue-033-535.el7.x86_64 151/167
Verifying : python-perf-3.10.0-862.el7.x86_64 152/167
Verifying : libmspack-0.5-0.5.alpha.el7.x86_64 153/167
Verifying : iwl3945-firmware-15.32.2.9-62.el7.noarch 154/167
Verifying : libss-1.42.9-11.el7.x86_64 155/167
Verifying : procps-ng-3.3.10-17.el7.x86_64 156/167
Verifying : libblkid-2.23.2-52.el7.x86_64 157/167
Verifying : open-vm-tools-10.1.10-3.el7.x86_64 158/167
Verifying : kpartx-0.4.9-119.el7.x86_64 159/167
Verifying : krb5-libs-1.15.1-18.el7.x86_64 160/167
Verifying : nss-3.34.0-4.el7.x86_64 161/167
Verifying : iwl5000-firmware-8.83.5.1_1-62.el7.noarch 162/167
Verifying : systemd-219-57.el7.x86_64 163/167
Verifying : yum-plugin-fastestmirror-1.1.31-45.el7.noarch 164/167
Verifying : systemd-libs-219-57.el7.x86_64 165/167
Verifying : 1:mariadb-libs-5.5.56-2.el7.x86_64 166/167
Verifying : e2fsprogs-1.42.9-11.el7.x86_64 167/167
Installed:
Updated:
