Hi there,
CyberPanel is working correctly and the websites are working fine.
But whenever I reboot the VPS everything goes down.
So then, I stop the firewall from CLI and everything starts to work again.
The bottom line is whenever the firewall is up everything else is down.
Btw, I checked the firewall status from CLI and found the following errors:
ERROR: '/usr/sbin/ebtables-restore --noflush' failed: ebtables-restore v1.8.4 (nf_tables):
line 3: CHAIN_USER_DEL failed (Device or resource busy): chain PREROUTING_direct
line 3: CHAIN_USER_DEL failed (Device or resource busy): chain POSTROUTING_direct
line 3: CHAIN_USER_DEL failed (Device or resource busy): chain OUTPUT_direct
line 7: CHAIN_USER_DEL failed (Device or resource busy): chain INPUT_direct
line 7: CHAIN_USER_DEL failed (Device or resource busy): chain OUTPUT_direct
line 7: CHAIN_USER_DEL failed (Device or resource busy): chain FORWARD_direct
3]: ERROR: COMMAND_FAILED: '/usr/sbin/ebtables-restore --noflush' failed: ebtables-restore v1.8.4 (nf_tables):
What to do?
@josephgodwinke Any advice?
