I have a huge Media rich website (3GB in size) that I want to migrate to my new server with Cyber panel. I tried to upload it through the file manager but it says “can not be uploaded, Error message:”
What should I do?
What should I do?
1 - Upload using filezilla
2 - When upload finishes, go file manager, click “Fix Permissions” button
@tmoore File Zilla is very slow, to be honest.
I tried the same with the Command line but I can’t access the directories inside the /home directory.
Any suggestions?
Thanks for the reply though.
Compress it into a single zip file, upload the zip file by FileZilla, fix permissions, extract using file manager.
That way as it’s a single file, you are only limited by your upload speed and not by FileZilla sending it file-by-file.
Edit: If you can’t access it using command line, just go into root with sudo
P.S: Filezilla being slow means you have the 2 default connections and not the 10
@tmoore In that case, I better look into it.
Thanks a ton!
FileZilla → Edit → Configurations → Transfers
Change connections from 2 to 10.
But, compressing it all into a big zip file, uploading and fixing permissions should do it
