Honestly, I’m about to give up using this panel.
I’ve spent weeks already trying to set this up and never find an installation option that doesn’t present any common error or problem listed months ago or years ago and are always there.
Whatever the version of the panel or the Linux system, it is possible that nothing works 100% as it should work.
I’ve tested all the options and always have problems and more problems, whatever the configuration.
And it seems that they are common problems, just do a brief search here and you realize that they always appear again no matter what configuration you do.
All right it’s open-source and supported by standalone developers, but why don’t they test things before they release?
Even if it leaves a version with outdated dependencies and technologies as long as they work is great. Now upgrade and not make sure that everything works is a pity.
