I try in cyberpanel and it says generated “successfully” but I get a mail reporting:
[12.01.2022_08-23-09] We had errors while creating DKIM record for: intervalle-arts.com. Error message: Command '[‘cat’, ‘/etc/opendkim/keys/intervalle-arts.com/default.txt’]’ returned non-zero exit status 1…
I’ve also tried in SSH with > opendkim-default-keygen
I get the error message:
Generating default DKIM keys: perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_CTYPE = “UTF-8”,
LANG = (unset)
are supported and installed on your system.
perl: warning: Falling back to the standard locale (“C”).
Hi, I think the issue is something more fundamental. I’ve opened up another thread as it requires elaboration. I’m honestly thinking I might just delete everything and start again.
