Hello Team,
I have followed article to install the Spamassassin, all of the files look like to install to server. But the CyberPanel interface is displayed “SpamAssassin is not installed”
Also, I can not start the Spamassassin, and display below.
[root@carrie ~]# service spamassassin start
Redirecting to /bin/systemctl start spamassassin.service
Job for spamassassin.service failed because the control process exited with error code. See “systemctl status spamassassin.service” and “journalctl -xe” for details.
[root@carrie ~]# systemctl status spamassassin.service
● spamassassin.service - Spamassassin daemon
Loaded: loaded (/usr/lib/systemd/system/spamassassin.service; disabled; vendor preset: disabled)
Active: activating (start) since 日 2019-04-07 18:39:58 CEST; 6s ago
Process: 7002 ExecStartPre=/sbin/portrelease spamd (code=exited, status=0/SUCCESS)
Control: 7004 (spamd)
CGroup: /system.slice/spamassassin.service
└─7004 /usr/bin/perl -T -w /usr/bin/spamd --pidfile /var/run/spamd.pid -d -c -m5 -H
4月 07 18:39:58 server.carriechan.com systemd[1]: Starting Spamassassin daemon…
4月 07 18:39:59 server.carriechan.com spamd[7004]: server socket setup failed, retry 1: spamd: could not create IO::Socket::IP socket on [::1]:783: Cannot assign requested address
4月 07 18:40:00 server.carriechan.com spamd[7004]: server socket setup failed, retry 2: spamd: could not create IO::Socket::IP socket on [127.0.0.1]:783: Address already in use
4月 07 18:40:01 server.carriechan.com spamd[7004]: server socket setup failed, retry 3: spamd: could not create IO::Socket::IP socket on [127.0.0.1]:783: Address already in use
4月 07 18:40:02 server.carriechan.com spamd[7004]: server socket setup failed, retry 4: spamd: could not create IO::Socket::IP socket on [127.0.0.1]:783: Address already in use
4月 07 18:40:03 server.carriechan.com spamd[7004]: server socket setup failed, retry 5: spamd: could not create IO::Socket::IP socket on [127.0.0.1]:783: Address already in use
4月 07 18:40:04 server.carriechan.com spamd[7004]: server socket setup failed, retry 6: spamd: could not create IO::Socket::IP socket on [127.0.0.1]:783: Address already in use
4月 07 18:40:05 server.carriechan.com spamd[7004]: server socket setup failed, retry 7: spamd: could not create IO::Socket::IP socket on [127.0.0.1]:783: Address already in use
I have search on Google, it is due to IPv6 issues, but I do not have /etc/default/spamassassin file.
May I know how can I do? Many thanks =)
