i am facing 503 error on PHP script installation. …
Hello @lovechatzone
Fix file permissions using file manager
Go to Websites → mywpwebsite.com → File Manager → Fix Permissions
OR
You can use FTP to fix file permissions using a good client such as WinSCP, FileZilla, CyberDuck
How can i set permission ?? can you tell me more specific??
If pakchatzone.com is your domain then check if some failsafes might have been triggered, or its a DNS failure (missing dns records etc). If you are using cloudflare see the docs https://community.cloudflare.com/t/community-tip-fixing-error-503-service-unavailable-service-temporarily-unavailable/44438
https://community.cloudflare.com/t/503-server-unavailbe/110688/6
