Hi there,
I ran the usual upgrade to go from v2.3.1 to v2.3.2.
The final line of output says, Seems something wrong with upgrade, please check...
What should I be checking?
Looking through all the output from the upgrade procedure, search for obviously terms like failed
and error`, I see a number of potential issues. There’s too many characters to add to this one post. So I’ll put some into a reply.
WARNING: You are using pip version 20.2.4; however, version 21.3.1 is available.
ERROR: After October 2020 you may experience errors when installing or updating packages. This is because pip will change the way that it resolves dependency conflicts.
We recommend you use --use-feature=2020-resolver to test your packages with the new resolver before it becomes the default.
certbot 0.21.1 requires acme==0.21.1, but you'll have acme 1.9.0 which is incompatible.
sed: can't read /etc/yum.repos.d/MariaDB.repo: No such file or directory
[08.06.2022_21-38-15] #########################################################################
[08.06.2022_21-38-15] fix csf if there successful.
[08.06.2022_21-38-15] sed -i 's|sgp.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/MariaDB.repo failed, trying again, try number: 1
[08.06.2022_21-38-15] sed -i 's|sgp.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/MariaDB.repo failed, trying again, try number: 2
[08.06.2022_21-38-15] sed -i 's|sgp.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/MariaDB.repo failed, trying again, try number: 3
[08.06.2022_21-38-15] sed -i 's|sgp.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/MariaDB.repo failed.
[08.06.2022_21-38-15] sed -i 's|lax.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/MariaDB.repo failed, trying again, try number: 1
[08.06.2022_21-38-15] sed -i 's|lax.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/MariaDB.repo failed, trying again, try number: 2
[08.06.2022_21-38-15] sed -i 's|lax.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/MariaDB.repo failed, trying again, try number: 3
[08.06.2022_21-38-15] sed -i 's|lax.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/MariaDB.repo failed.
[08.06.2022_21-38-15] sed -i 's|fra.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/MariaDB.repo failed, trying again, try number: 1
[08.06.2022_21-38-15] sed -i 's|fra.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/MariaDB.repo failed, trying again, try number: 2
[08.06.2022_21-38-16] #########################################################################
[08.06.2022_21-38-16] sed -i 's|fra.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/MariaDB.repo failed, trying again, try number: 3
[08.06.2022_21-38-16] sed -i 's|fra.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/MariaDB.repo failed.
[08.06.2022_21-38-16] sed -i 's|mirror.cyberpanel.net|cdn.cyberpanel.sh|g' /etc/yum.repos.d/MariaDB.repo failed, trying again, try number: 1
[08.06.2022_21-38-16] sed -i 's|mirror.cyberpanel.net|cdn.cyberpanel.sh|g' /etc/yum.repos.d/MariaDB.repo failed, trying again, try number: 2
[08.06.2022_21-38-16] sed -i 's|mirror.cyberpanel.net|cdn.cyberpanel.sh|g' /etc/yum.repos.d/MariaDB.repo failed, trying again, try number: 3
[08.06.2022_21-38-16] sed -i 's|mirror.cyberpanel.net|cdn.cyberpanel.sh|g' /etc/yum.repos.d/MariaDB.repo failed.
sed: can't read /etc/yum.repos.d/litespeed.repo: No such file or directory
[08.06.2022_21-38-16] sed -i 's|sgp.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/litespeed.repo failed, trying again, try number: 1
[08.06.2022_21-38-16] sed -i 's|sgp.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/litespeed.repo failed, trying again, try number: 2
[08.06.2022_21-38-16] sed -i 's|sgp.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/litespeed.repo failed, trying again, try number: 3
[08.06.2022_21-38-16] sed -i 's|sgp.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/litespeed.repo failed.
[08.06.2022_21-38-16] sed -i 's|lax.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/litespeed.repo failed, trying again, try number: 1
[08.06.2022_21-38-16] sed -i 's|lax.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/litespeed.repo failed, trying again, try number: 2
[08.06.2022_21-38-16] sed -i 's|lax.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/litespeed.repo failed, trying again, try number: 3
[08.06.2022_21-38-16] sed -i 's|lax.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/litespeed.repo failed.
[08.06.2022_21-38-16] sed -i 's|fra.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/litespeed.repo failed, trying again, try number: 1
[08.06.2022_21-38-16] sed -i 's|fra.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/litespeed.repo failed, trying again, try number: 2
[08.06.2022_21-38-16] sed -i 's|fra.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/litespeed.repo failed, trying again, try number: 3
[08.06.2022_21-38-16] sed -i 's|fra.cyberpanel.sh|cdn.cyberpanel.sh|g' /etc/yum.repos.d/litespeed.repo failed.
[08.06.2022_21-38-16] sed -i 's|mirror.cyberpanel.net|cdn.cyberpanel.sh|g' /etc/yum.repos.d/litespeed.repo failed, trying again, try number: 1
[08.06.2022_21-38-16] sed -i 's|mirror.cyberpanel.net|cdn.cyberpanel.sh|g' /etc/yum.repos.d/litespeed.repo failed, trying again, try number: 2
[08.06.2022_21-38-16] sed -i 's|mirror.cyberpanel.net|cdn.cyberpanel.sh|g' /etc/yum.repos.d/litespeed.repo failed, trying again, try number: 3
[08.06.2022_21-38-16] sed -i 's|mirror.cyberpanel.net|cdn.cyberpanel.sh|g' /etc/yum.repos.d/litespeed.repo failed.
[08.06.2022_21-39-46] #########################################################################
[08.06.2022_21-39-46] CLI Symlink failed, trying again, try number: 1
ln: failed to create symbolic link '/usr/bin/cyberpanel': File exists
[08.06.2022_21-39-46] CLI Symlink failed, trying again, try number: 2
[08.06.2022_21-39-46] CLI Symlink failed, trying again, try number: 3
[08.06.2022_21-39-46] CLI Symlink failed.
[08.06.2022_21-39-53] #########################################################################
[08.06.2022_21-39-53] chown core code failed, trying again, try number: 1
usermod: group 'nobody' does not exist
[08.06.2022_21-39-53] chown core code failed, trying again, try number: 2
[08.06.2022_21-39-53] chown core code failed, trying again, try number: 3
[08.06.2022_21-39-54] chown core code failed.
[08.06.2022_21-39-54] #########################################################################
[08.06.2022_21-44-57] #########################################################################
[08.06.2022_21-44-57] chown core code failed, trying again, try number: 1
chmod: cannot access '/etc/yum.repos.d/MariaDB.repo': No such file or directory
[08.06.2022_21-44-58] #########################################################################
[08.06.2022_21-44-58] chown core code failed, trying again, try number: 2
[08.06.2022_21-44-58] chown core code failed, trying again, try number: 3
[08.06.2022_21-44-58] chown core code failed.
chmod: cannot access '/etc/pdns/pdns.conf': No such file or directory
[08.06.2022_21-44-58] chown core code failed, trying again, try number: 1
chmod: cannot access '/usr/local/lsws/conf/httpd_config.xml': No such file or directory
chmod: cannot access '/usr/local/lsws/conf/modsec.conf': No such file or directory
(continued in reply)
That seems like a lot of fails / issues for a routine update procedure. Is this normal?
Is there anything here I should be concerned about, or actions I should take?
The Dashboard is loading, and the websites are running.
Thank you.
