Hi!
The cloudlinux support has send me here with my problem…
So the problem is, if I want to use the php xray I get an error:
"The received data is wrong. Contact support for resolution. Traceback (most recent call last):
File “/opt/alt/python37/lib/python3.7/site-packages/vendors_api/parser.py”, line 117, in _validate
deserialized = json.loads(raw_data) or {}
File “/opt/alt/python37/lib64/python3.7/json/init.py”, line 348, in loads
return _default_decoder.decode(s)
File “/opt/alt/python37/lib64/python3.7/json/decoder.py”, line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File “/opt/alt/python37/lib64/python3.7/json/decoder.py”, line 355, in raw_decode
raise JSONDecodeError(“Expecting value”, s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
During handling of the above exception, another exception occurred:
File “/usr/sbin/cloudlinux-xray-manager”, line 16, in
run()
File “/opt/alt/python37/lib/python3.7/site-packages/xray/cli_utils/run_manager.py”, line 38, in run
manager_run(validated_args)
File “/opt/alt/python37/lib/python3.7/site-packages/xray/cli_utils/run_manager.py”, line 46, in manager_run
manager_instance = initialize_manager(args.system_id)
File “/opt/alt/python37/lib/python3.7/site-packages/xray/manager/init.py”, line 33, in initialize_manager
return m(system_id)
File “/opt/alt/python37/lib/python3.7/site-packages/xray/manager/custom.py”, line 48, in init
self.all_domains = self.get_all_domains()
File “/opt/alt/python37/lib/python3.7/site-packages/xray/manager/custom.py”, line 77, in get_all_domains
return self.api.domains(with_php=True)
File “/opt/alt/python37/lib/python3.7/site-packages/vendors_api/parser.py”, line 298, in domains
valid_data = self._execute(command, schema_file=schema)
File “/opt/alt/python37/lib/python3.7/site-packages/vendors_api/parser.py”, line 91, in _execute
return self._validate(output, schema_file)
File “/opt/alt/python37/lib/python3.7/site-packages/vendors_api/parser.py”, line 119, in _validate
raise MalformedError(raw_data)
vendors_api.exceptions.MalformedError: vendor api returned invalid response that cannot be parsed with json, output:"
The cloudlinux support says the cyberpanel API the problem, what can I do?
