[01.28.2024_18-38-23] ########################################################## ###############
Reading package lists… Done
Building dependency tree
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
mariadb-server : Depends: galera-4 (>= 26.4) but it is not going to be installe d
Depends: mariadb-client (>= 1:10.11.6+maria~ubu2204) but it is not going to be installed
Depends: mariadb-server-core (>= 1:10.11.6+maria~ubu2204) but it is not going to be installed
Depends: libc6 (>= 2.34) but 2.31-0ubuntu9.14 is to be install ed
Depends: libssl3 (>= 3.0.0~~alpha1) but it is not installable
Depends: libstdc++6 (>= 11) but 10.5.0-1ubuntu1~20.04 is to be installed
Recommends: libhtml-template-perl but it is not going to be in stalled
Recommends: pv but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
[01.28.2024_18-38-23] Running DEBIAN_FRONTEND=noninteractive apt-get install mar iadb-server -y failed. Running again, try number 3
[01.28.2024_18-38-23] [ERROR] We are not able to run DEBIAN_FRONTEND=noninteract ive apt-get install mariadb-server -y return code: 100. Fatal error, see /var/l og/installLogs.txt for full details.
Oops, something went wrong…
root@54:~#
This error appears in : ubuntu 20 and 18 and centos 7 and 8
how i can fix it please
