For now, upgrade does not run for your version, did you tried restarting gunicorn socket?
systemctl restart gunicorn.socket
Did not help.
The update could not be done. When manually updating: https://forums.cyberpanel.net/discussion/comment/860#Comment_860
It completely stopped working.
In the installer, np was missing /usr/local/CyberCP/bin/.
The entire Cyberpanel stopped working. There is some error in the update system.
I have to install everything from scratch.
CyberPanel has stopped working. After adding the ‘bin’ directory with the contents, it worked but did not have css.
I am now installing from the beginning. the updates probably need to be improved.
A few days ago I asked for github and here for adding polish and how to add translation and updates.
CyberPanel has stopped working. After adding the 'bin' directory with the contents, it worked but did not have css.
Edit this file via any editor, recommended is poedit. Once done you can send this file via private message or ticket.
I have already been translated in most cases. I also found * .py * .html files with no ‘{% trans “…” %}’ markers inserted. I wanted to report it. I’m using ‘msgunfmt’ ‘msgunfmt’.
In the new version, I often get errors:
[Errno 2] No such file or directory: u’/home/cyberpanel/8567’
[Errno 2] No such file or directory: u’/home/cyberpanel/9484’
Virtual Host Directory already exists. [404]
I’ll check with today’s update and I’ll send you updated with it.
Only here I do not have permission to send attachments in PM like using the forum code.
