Error "python setup.py egg_info did not run successfully" while installing cyberpanel
Error shows up while installing and its looping.
OS: Ubuntu 22.04 , Aws
Collecting decorator==3.4.0
  Using cached decorator-3.4.0.tar.gz (30 kB)
  Preparing metadata (setup.py) ... error
  │ exit code: 1
  ╰─> [1 lines of output]
      error in decorator setup command: use_2to3 is invalid.
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
Thanks,
Welcome @Azx Happy you are here
Seems to be an issue with pip, wheel, setuptools
You need to do a clean installation by restoring to an earlier snapshot when you first leased server or straight up reinstall the os
Kindly post the results of this command before you install
$ python --version
