I install on XEN VPS with Centos 7.2, already Install Phyton 3.6 too, but it gives me this error:
keywords=['interface', 'components', 'plugins'],
File "/usr/lib64/python2.7/distutils/core.py", line 112, in setup
_setup_distribution = dist = klass(attrs)
File "/usr/lib/python2.7/site-packages/setuptools/dist.py", line 269, in __init__
_Distribution.__init__(self,attrs)
File "/usr/lib64/python2.7/distutils/dist.py", line 287, in __init__
self.finalize_options()
File "/usr/lib/python2.7/site-packages/setuptools/dist.py", line 302, in finalize_options
ep.load()(self, ep.name, value)
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 2316, in load
return self.resolve()
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 2326, in resolve
raise ImportError(str(exc))
ImportError: 'module' object has no attribute 'check_specifier'
Command “python setup.py egg_info” failed with error code 1 in /tmp/pip-build-bt9Pn9/zope.interface/
You are using pip version 9.0.1, however version 10.0.1 is available.
You should consider upgrading via the ‘pip install --upgrade pip’ command.
[01-47-04-Wed-Apr-2018] #########################################################################
[01-47-04-Wed-Apr-2018] Trying to install CertBot, trying again, try number: 3
[01-47-04-Wed-Apr-2018] Installation failed, consult: /var/log/installLogs.txt
