Hello
here are the logs when trying to install cyberpanel on scaleway european cloud
centos 7…6
[12.23.2019_14-10-32] ########################################################## ###############
[12.23.2019_14-10-32] [ERROR] We are not able to run rpm -ivh https://rpms.lites peedtech.com/centos/litespeed-repo-1.1-1.el7.noarch.rpm return code: 1. Fatal e rror, see /var/log/installLogs.txt for full details.
Oops, something went wrong…
[root@sdfdsfsdfds ~]# nano /var/log/installLogs.txt
-bash: nano: command not found
[root@scw-pensive-blackwell ~]# vi /var/log/installLogs.txt
[12.23.2019_13-21-56] Running: yum install sudo -y
[12.23.2019_13-21-57] Successfully ran: yum install sudo -y.
[12.23.2019_13-21-57] Running: useradd -s /bin/false cyberpanel
[12.23.2019_13-21-58] Successfully ran: useradd -s /bin/false cyberpanel.
[12.23.2019_13-21-58] Running: adduser docker
[12.23.2019_13-21-58] Successfully ran: adduser docker.
[12.23.2019_13-21-58] Running: groupadd docker
[12.23.2019_13-21-58] [ERROR] We are not able to run groupadd docker return code: 9.
[12.23.2019_13-21-58] Running: usermod -aG docker docker
[12.23.2019_13-21-58] Successfully ran: usermod -aG docker docker.
[12.23.2019_13-21-58] Running: usermod -aG docker cyberpanel
[12.23.2019_13-21-58] Successfully ran: usermod -aG docker cyberpanel.
[12.23.2019_13-21-58] Running: mkdir -p /etc/letsencrypt/live/
[12.23.2019_13-21-58] Successfully ran: mkdir -p /etc/letsencrypt/live/.
[12.23.2019_13-21-58] Running: yum update -y
[12.23.2019_13-22-04] Successfully ran: yum update -y.
[12.23.2019_13-22-04] Running: rpm -ivh https://rpms.litespeedtech.com/centos/litespeed-repo-1.1-1.el7.noarch.rpm
[12.23.2019_13-22-05] Successfully ran: rpm -ivh https://rpms.litespeedtech.com/centos/litespeed-repo-1.1-1.el7.noarch.rpm.
[12.23.2019_13-22-05] Running: yum -y install epel-release
[12.23.2019_13-22-10] Successfully ran: yum -y install epel-release.
[12.23.2019_13-22-10] Running: yum -y install python-pip
[12.23.2019_13-22-11] Successfully ran: yum -y install python-pip.
[12.23.2019_13-22-11] Running: yum -y install python-devel
[12.23.2019_13-22-13] Successfully ran: yum -y install python-devel.
[12.23.2019_13-22-13] Running: yum -y install gcc
[12.23.2019_13-22-14] Successfully ran: yum -y install gcc.
[12.23.2019_13-22-14] Running: yum -y install python-setuptools
[12.23.2019_13-22-16] Successfully ran: yum -y install python-setuptools.
[12.23.2019_13-22-25] Running: yum -y install MySQL-python
[12.23.2019_13-22-32] Successfully ran: yum -y install MySQL-python.
[12.23.2019_13-22-32] Running:
[12.23.2019_13-22-32] Successfully ran: .
[12.23.2019_13-22-32] Running: yum install -y openlitespeed
[12.23.2019_13-22-56] Successfully ran: yum install -y openlitespeed.
[12.23.2019_13-22-56] Changing default port to 80…
[12.23.2019_13-22-56] Default port is now 80 for OpenLiteSpeed!
[12.23.2019_13-22-56] Running: /usr/local/lsws/bin/lswsctrl restart
[12.23.2019_13-22-58] Successfully ran: /usr/local/lsws/bin/lswsctrl restart.
