But when once I click launch I get the following error
( Operation Failed! Websites matching query does not exist.)
and when I edit and set the required limits I also get the same error.
containerization doesnt works best all time still you can try and make if work fine. It is limited to CentOS and CentOS is getting end of life soon. Anyways which Centos version are you using here?
Its best to use Cloudlinux for limiting server resources as they have better functions and kernel modifications to handle all these effectively.
Last metadata expiration check: 1:30:08 ago on Wed Jan 19 05:19:29 2022.
Package libcgroup-tools-0.41-19.el8.x86_64 is already installed.
Dependencies resolved.
Nothing to do.
Complete!
Failed to enable unit: Unit file cgred.service does not exist.
Packages successfully installed.[200]
