I have using CyberPanel for a week. I add a wordpress site and I am very satisfied about sites performance.
But I take database errors sometimes that I open 2-3 tabs on WP Panel or some plugin WP pages. But this is not always.
I changed the tuning about php-litespeed from CyberPanel and than the database problem solved. This time only I took 2-3 times connections timeout error.
But performance decreased a bit and I reload old tuning settings. And again I am taking “Error establishing a database connection” when I load a bit much on WP panel.
So first - test how your site will work with Litespeed cache plugin for wordpress. Second - you can use it to optimize your images (you have a lot on index). Third - 180 request on the index are a lot. try to reduce them. That way you site will use less ram.
Hi Tishu.
The error about establishing database is about much ram? Does it give error for the maximum ram limit?
