This error occurs again while sending the mail to “[email protected]”
Now it is related to PTR records…
What are the PTR records?
Are you there?
Plz help me i am too much worried about this issue
Result report for “[email protected]”
is anyone here plz?
You need to create rDNS PTR record on your server. Contact your server provider for help. They should show you where you manage your server from; how to add these records
they always said that VPS is unmanaged by us…i think we have to do at our end
Which service provider is this ?
Hostinger is the provider
I purchased using hostinger
Quick google search shows this How to Use PTR Records on VPS | Hostinger Help Center you already have everything to do this, even pictures.
but my question is, why still it is showing unsecure mailerver access?
I already upgrade the cyberpanel and reboot the server, also reissue the mailserver SSL
I will try
Fix one issue at a time. Reason why I ased you if you followed what you already have here on thr forum
ERROR: Can't send email using cyberpanel snappymail - #4 by josephgodwinke
let me add the records first
Can you check these?
It should work now or should i wait for 24 hours to propagate it
Just keep checking every 30mins
ok i will see
But how to solve the ssl issue?
