Good now show me the results of //email/testTo: testing an email address of same domain
Just try to send an email for now
ok
its not going to some emails
are you there?
recent test to this email " [email protected]"
lets stop this for now and start again from tomorrow.
still there are some issues in mail…but we will see it tomorrow
thanks for your help
My email is now working fine but ssl is not working with mailserver “http://siteIPaddress/snappymail/index.php”
what may be the issue
This is the issue ERROR: Can't send email using cyberpanel snappymail - #86 by faheemkiani
Mailserver ssl is selfsigned
Run
$ postmap -F hash:/etc/postfix/vmail_ssl.map
$ systemctl restart dovecot
$ systemctl restart postfix
ok let me run this
Is there any other way to install ssl again?
Try this guide see if your issue goes away Self Signed SSL Issue · josephgodwinkimani/cyberpanel Wiki · GitHub
Does this work ? Search results for 'https://github.com/josephgodwinkimani/cyberpanel/wiki/Self-Signed-SSL-Issue status:solved' - CyberPanel Community
just confirm me, the way i used your mentioned commands or correct or not?
Yes the commands worked. Seems the ssl is self-signed we need to issue it. This is a problem with Let’s Encrypt not cyberpanel
this method is correct of using the commands …just confirm plz
can we reissue the ssl for mailserver?
We tried that it didnt work. Thats why I was suggesting another fix
let me try to do that
